Question about LG LS-L1210CL Mini Split Air Conditioner
CO code when shutting off with remote.
I too have this problem!!! Exactly as you described.
    Scholar:
  • 70 Answers
Try washing out outside coil and the check to see if inside coil is cold from top to bottom after the coil is dry outside and system run for a few mins. If it starts to freeze on just a small portion of inside coil then it may be low on refrigerant or bad tx valve. Do not run unit leak is repaired or metering valve replaced and unit is recharged. Compressor can be damaged with repeated starts. can't say what co means but it is a lock out for a reason .
Posted on Jun 30, 2009
Need remote code for Vizio D32h-CO. No remote for TV. Have Dish remote
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Jan 18, 2018 | Vizio Televison & Video
Is there a remote for a Panasonic SA-AK250?
Yes the SA-AK250 (main unit of the Panasonic SK-AK250) came with a remote control. The remote is described on page 7 of the manual, available from Panasonic NZ here: https://support.panasonic.co.nz/docstore/SC-AK250%20Operating%20Instructions.pdf . The part number of the remote is N2QAYB000142; it's listed on page 1 of the manual. There are some online vendors that claim to have the remote available. I do not know if these are trustworthy vendors.
Some universal remotes may work, if they have codes for Panasonic audio systems. However, I don't know which ones may work. I hope this helps
Jan 14, 2016 | Panasonic Audio Players & Recorders
What is the remote code for Currys Essential TV C15DVDBIO?
Have you tried the method on page nine of the remote user manual? The remote should be able to find it by using the search method as described at the top of the page.
http://www.oneforall.co.uk/uploads/support/3e9bf5472f568ec483ebd97a3bd72927.pdf
Jan 15, 2013 | Televison & Video
Hello, I have lost the manual of my welltech ls023 and i need to know the codes for my tv....
My Welltech LS023 remote operates exactly the same as the Tevion MD83388 remote (both from Aldi?). A manual for the Tevion can be downloaded from www.medion.co.uk. You don't need a code list since they are programmed into the device by manufacturer.
Jul 09, 2012 | Televison & Video
I am looking for repalcement spring for my bebecar pram
You should get in touch with service@bebecar.co.uk. Be prepared to describe exactly what spring it is that you require, and you may find it useful to provide a photograph.
Jan 29, 2011 | Bebecar Raider AT Stroller
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
See below
Press and hold the desired device key - TV, CABLE, or VCR - until the red light stays on. Turn on the corresponding device and press the remote's POWER key repeatedly until the device shuts off. Press STOP and the code will be stored.
May 21, 2009 | RCA Universal Remote Control
LG wall unit reads "Co" when I try to shut it off with remote.
It's related to cleaning try to on-off auto cleaning... Works for me
May 01, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
TV SETUP CODE
I have found out the solution to this problem.Don t listen to Sky ,just buy your self a latest" series 8 sky plus remote control "and at about £12.00 0n ebay.Then all you do is phone LG customer services with you TV model number.If you have any probs email me at allyballybea@tiscali.co.uk.
Nov 26, 2007 | LG 42LC2D 42 in. LCD HDTV
LG LS-L1210CL Mini Split Air Conditioner Logo
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
