This usually is cause when the computer cannot find the boot program on you HDD. But there are other causes also. Before going to the boot program let's check other things first. Your primary boot sequence in the CMOS setup is not set to you primary HDD and the computer looks for the boot system in the CD/DVD/Blueray disk drive or USB and couldn't find any boot program. But normally it would skip those and go to your primary HDD. But if you have those CD/DVD or a USB stick, external HDD plugged in then remove them and try rebooting again. If that doesn't work, than you have a defective HDD. Check your HDD, try recovering with windows recovery disk. Worst thing, Reinstall windows again, install new HDD and reinstall windows.
Sorry for the later suggestions.
Good luck
SOURCE: dell inspiron 8000 without operating system
First, if you are still running Vista on your desktop then you will need to buy a license for the laptop. Does the laptop have a WinXP on it now? If so, go here http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx and run the Vista Upgrade Advisor. If not, determine the hardware specifications of your laptop and go here http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx Compare your laptops specs to those listed for the version of Vista you wish to install.
SOURCE: How do I restore my dell inspiron 2650 to factory
If your system is PC Restore Equipped, it will show show a black page with a blue bar across the top after the Dell Splash Screen. the bar will have www.dell.com in White letters. If you see this page for about a second during the boot process, the system is PC Restore Equipped. At the page with the blue bar, press CTRL+F11 and that will initiate the restore process. Providing the image is not damaged, then restore process takes about 20 to 30 minutes and will return the system to out of box configuration. If there are any errors or if the PC Restore page is not available, then you'll have to do a clean install of Windows using the Dell Windows XP CD that came with the system, then load drivers and applications.
SOURCE: my Dell inspiron mini, does not boot up. It tells
Run the recovery console or ask Dell to send a disk.
SOURCE: where is switch for wireless on inspiron 2650
hello,
the Dell Inspiron 2650 PC Notebook does not have a wireless lan services.
it only operates with a cabled network service.
take care
SOURCE: Does the Dell Inspiron 2650 Model PP04L have Wifi
Hi jenralley, !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
"The "Specifications" do not show {Wifi Capability}.
There is a "built-in Mode," with built-in Network Interface."
"This is use for "Broadband Services." Telephone and DSL {Cable} Internet!"
Specifications
Base configuration
Good
CPU
1.6-GHz Pentium 4-M
Screen size
14.1 inches
System memory
256MB of DDR266 SDRAM
Hard drive
30GB
Graphics
16MB NVidia GeForce2 Go
Pointing device
Touchpad
Expandability
No multipurpose bays, one PC Card slot
Extra features
Good
Bundled removable-media drives
8X DVD-ROM and 8X/8X/24X CD-RW combination drive
Communications
Built-in V.92 modem, built-in network interface
Extra ports
None
Business suite
Microsoft Works 2002
Other features
None of note
Overall design
Average
Battery life (hours:minutes)
Average: 2:18
Weight (typical/minimum, in pounds)
Heavy: 8.3/7.2
