Question about LG DH30 GoldStar Dehumidifier
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
  • 867 Answers
There may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Posted on Jun 24, 2009
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
LG unit has run great for 4 years and now does not produce any water. Seems to run fine, filter is clean, can hear compressor starting. Just does not dehumitify.????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 06, 2011 | LG LHD45EL Dehumidifier
Simplicity dehumidifier (SDR505R) not working
Danby dehumidifiers are craps - I have been trying to buy an used dehumidifier. I've looked at several for sale on Kijiji and Craigtslist - the majority of them is by Danby - None of them works. Fan and compressor run but no condesation occurs at the coil i.e. no water dripping into the bucket. Solution: scrap it. Refilling the gas costs more than a new dehumidifier. They are not made for refilling like the compressor in a car.
Aug 10, 2009 | Dehumidifiers
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
Not collecting water,
IF THE COMPRESSOR QUITS IT WILL NOT PRODUCE MOISTURE COULD BE LOW ON GAS,BAD HUMIDISTAT,DIRTY CONDENSOR CAUSING UNIT TO OVERHEAT SHOULD SEEK TECHNICIAN
Jul 20, 2009 | LG DH30 GoldStar Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Dehumidifier will not shut off
The auto shut off will work when you have your bucket in, as well when you have met the humidy level which you have chosen. Try changing the setting.
Sgt 48
Jun 04, 2008 | LG DH30 GoldStar Dehumidifier
Fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Oct 23, 2007 | Comfort-Aire BHD-651 Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
760 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
