My 2000 honda 50cc starts and runs only with ckoke on, dies out if you take the choke off even with high rev
had the same problem before. What you need to do is to cancel out those basics that prevents the engine from running.
1. Check the spark plug, poor spark causes poor engine performance.
2. Poor fuel. Make sure no water is in the carburetor.
3. Idling problem or fuel-air mixture.
Quick Fixes:
1. Rev the engine with the choke ON. rev for at least 30 seconds to drive moisture out.
2. Drain the carburetor for any water deposits. This makes a bad mixture in the combustion.
3. Clean your spark plug.
4. Tune your Fuel-Air mixture to 2.5 turns out... Turn it clockwise until it stops and make 2.5 turns out. That's the standard.
5. Set your idle later if the engine's hot enough for idle run.
Your problem mostly is caused by poor fuel dispersion. Since pulling the choke entails less air and more fuel, it could be that that your engine requires more of it. If you have the time to remove the carburetor for disassembly, i recommended doing so. Remove the carb and clean the jets, make sure you put everything back in order.
That's it.. Let me know if there's any more problems... this is my usual approach.
I hope it helps,
levibit
