Question about E-Machines T5082 PC Desktop
Computer will not boot up
My e machines t5082 will light up when i turn it on however has no signal to the monitor, the cooling fan also runs at high speed,constantly. i have replaced the power supply and still have nothing, same symptoms. this all resulted from a power surge when the power went out and the unit made a loud popping noise???
    Scholar:
  • 106 Answers
Sounds like the bios is not posting. Your motherboard could be damaged.
Try this though. Recheck that your keyboard and mouse are plugged into the right holes on the back, sometimes having these switched will not let the computer boot. Also, after switching them, unplug the power supply from the computer, and replug it.
Don't buy Emachines. Their power supplies are made to fail within the year. There are plenty of other 200$ PCs to buy.
The good news is, your hardrive data is fine.
Posted on Jun 24, 2009
  • 3 Answers
You can try replacing just the video card if it is not integrated, but if it does not fix, you will have wasted money buying one, unless you can borrow one. The main thing is your data on the HD. you need to remove the HD and hook it up as a slave on another similar OS computer so you can recover your info. if your Hard Drive is undamaged you can at least retrieve your docs, music etc.
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Computer won't boot.
Yea your processor has overheated. It can be replaced this is what you need https://www.upgradebay.com/c1_itemdetail.asp?rid=22&itemid=168714521 I would open up the bay door and take a look at the main fan that is attached to the motherboard. If you can get that off then you will be able to see the chip that you need to replace. Make sure to put on a bit of thermal grease before you put the fan back on your new CPU as this was the reason your old one crapped out. Good luck!
Sep 23, 2009 | E-Machines T5082 PC Desktop
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
T1150 emachine Computer not booting up correctly
did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Nov 29, 2008 | E-Machines T1150 PC Desktop
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Powering up problems.
Try using another monitor that you know works. Then try another video card. The fans are running because the computer is running ---but the monitor is not. Green to Amber means monitor is not on.
A lot can go wrong with loose wires that shouldn't be loose.
But I would try this first.
Jul 22, 2008 | E-Machines eMachines Desktop PC
T5082 keeps abruptly shutting down
Sounds like it may be overheating. If you get warning beeps on startup that sounds high, low, high low, it is overheating. you should inspect and clean the fan on the processor with a vacuum or compressed air ans also clean the power supply area with a vacuum to clear all the dust out. Inspect and wipe any other dust away from the motherboard and card inside. After restarting, it still goes off, check that the fan is running during startup. If not, the fan needs to be replaced at a nominal cost. This is an easy fix. If this all fails, let me know so we can troubleshoot everything together.
Nov 19, 2007 | E-Machines eMachines Desktop PC
E-Machines T5082 PC Desktop Logo
294 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
