Question about Amana Heating & Cooling
Airconditioner not cooling
I have 21 yr old Amana unit that was running but not cooling. Just had a/c guy out to look at it. He refilled refrigerant, but it still does not bring inside temp down. He mentioned that coils inside furnace may be frozen and to leave a/c off for a while to defrost. How long would that take? Could there be another problem besides age of the unit?
  • 334 Answers
Hey ther, you got an old unit there. Usually 24 hours is more than enough time to thaw a coil out. If you leave your fan on it goes a lot quicker but all depends on how much ice it has. Usually a frozen coil is an easy fix but not always. You could be low on refrigerant (make sure they find the leak if it is recharged otherwise it will just happen again), Another cause is dirty filter, or dirty coil, or dirty fan ( probably this since it is old. The last cause is a restriction in the refrigerant lines. That is an expensive fix because they have to pull the refrigerant ot to fix. You shouldn't need any parts regardless except possibly a filter drier or metering device (both can be the restriction in the refrigerant line)
Good Luck
seth
Posted on Jun 24, 2009
Refrigerator not running, not cooling
check power line to be cut,circuit breaker,main outlet for fridge ,then expert professional
Sep 29, 2014 | Amana Refrigerators
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 11, 2011 | Amana Heating & Cooling
My refrig just stopped cooling/freezing. 6/7 yr old side by side Amana asd262rhrw. the motor has been louder lately
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Refrigerators
Hi ! love my 15 yr old walkin Amana fridge freezer ,but lately its really loud for long periods then reverts to it usual sound level or absolutely silent !
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | Amana SXD524VW Side by Side Refrigerator
We have a amana refrigerator that is 6 years old and i was told the compresser went out. Should that happen to a 6 yr fridge?
The compressor is an electrical device and then can fail at any time....there is no reliable way to totally predict the life span... power surges and power conditioning can also affect the reliability of the device....
heatman101
Oct 20, 2010 | Amana ABB1927DE Bottom Freezer...
We have a3 yr old Goodman CAPF3030B6AA Airconditioner and Furnace. The Air conditioner hasnt worked right all summer. Its 102 degrees outside and we can set the thermostat on 72 degrees and it will be...
A/C units have a design temperature of 90F. Now when the temperature is above 90F they start to have trouble keeping up. Depending on how well your unit is sized for the house, you will notice when the temp is over 90F. I don't know if who ever looked at your unit checked the refrigerant pressures since you said he checked the temps but I assume he did, however, it could possibly need charging.
Aug 05, 2010 | Heating & Cooling
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
6 yr old Amana has stopped cooling- light is on!
To make sure there is no damage to the compressor I want you to unplug the refrigerator. I will instruct you on what to test or advise you on how the repair should take place. If this is what you want, let me know. The problem could be something simple but to do these test answer me about this solution. Thanks, Sea Breeze
Jun 30, 2009 | Amana ABB1927DE Bottom Freezer...
Heating & Cooling Logo
135 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
