Question about Amana ARB190ZCS Bottom Freezer Refrigerator
REFRIG WILL NOT GET ANYTHING COLD
A few days ago my freezer door was left open... happen like 3x in a week... nOW THEBOTTOM FREEZER WILL NOT GET COLD FOR NOTHING AND THE TOP PART EITHER... THE LIGHT IS ON I FEEL A LITTLE AIR BUT ITS NOT COLD AT ALL... PLEASE ADVISE WHAT CAN I DO mODEL ARB190ZCS AMANA
  • 999 Answers
Make sure there is no frost buildup behinde the freezer back panal and the ducts to the frig are clear. Leaving the door open will make a lot of frost and diminish the cooling capacity.
Eric
Posted on Jun 24, 2009
  • 351 Answers
Compressor running? is it hot? is the condensor fan motor running? is the evaporator fan running? is the cold control/thermostat on?
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Lg refrigerator leaking and freezer issue
Honestly, most people are not experienced on LG to know all the symptom and their solution. I guess you will have to wait for it to break again to have it fixed.
Oct 25, 2013 | Refrigerators
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Moved Side By side w/Dolly now Refrig side is not working
I have seen this happen so many times with all appliances.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer. The settings may both be numbers however, they work the same way as described above.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system but, this would also cause the freezer side to not get cold after 2 weeks.
Feb 11, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator and Freezer not getting cold?
unplug the machine and let it completely defrost with the doors open overnight. then try it. if it still does not get cold then you know it is a more serious problem, like a compressor $300+
if it works for a couple days then freezes up again then you know it is a defrost problem, less serious problem <$100
Jun 28, 2008 | Maytag MSD2655HES Side by Side...
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Amana ARB190ZCS Bottom Freezer Refrigerator Logo
219 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
