Question about i-Bulldog IMP-90 MP3 Player
Lost cover to battery
How or where can i purchase a cover to hold battery in?
Re: lost cover to battery - i-Bulldog IMP-90 MP3 Player MP3 & Digital Media Players
Buy a new ibulldog imp-90 256mb mp3 player
Posted on Dec 25, 2007
0 characters
3 Points
Hallo, is there a link for an online guide that shows me how to replace the battery of my iriver140? It wount charge, as it only gets warm! Thanks!
Hi, 1) Make sure the player is switched off and the hold switch is on.
2) Remove the screw from each side cover.
3) Remove the 4 screws from each end cap and then remove end caps.
4) The rear cover and side covers can now be removed and the battery removed from the rear cover.
Note: The battery will most likely to be stuck to the rear cover and care should be taken not to put excessive force onto the battery wires when removing the cover. The internal microphone is mounted on one of the side covers and care should also be taken with it so as not to damage the wires.
5) The hard drive can now be removed by lifting and gently pulling it out.
6) Remove the six screws holding the mother board to the front cover. the circuit board may now be removed.
It is a good idea to take note of the routing of the battery wires before removing the mother board.
7) Disconnect the molex plug from the board , this is made easier by lifting the rear of the plug as you remove it.
8) check the polarity of the new battery is the same as the original (they are rarely wrong and need changing).
If it requires changing the terminals can be released by lifting the tags as shown here in the h3xx battery replacement thread.
9) Reassembly is the reverse of disassembly taking note of the following:
a) Check the battery wires are correctly routed to avoid pinching and damage.
b) Check the hold switch slide is aligned with the switch when refitting the side cover.
Have a nice day......
Mar 04, 2011 | iRiver iHP-140 MP3 Player
I was charging it nd it was chrage nd out of no where it turn off nd never turn back on nd it doesnt chrage no more
Hold the power button and the home button down at the same time for 20 seconds. if it still doesn't power on, try to put it into DFU mode and plug it into iTunes to restore it:
1. Hold the power button and home button for 10 seconds.
2. Let go of the power button and continue holding the power button.
Mar 01, 2011 | Apple iPod touch 1st Generation (8 GB) MP3...
Walkman NWZ-S615F How do you change the battery on this walkman? We've had it 3 years, but hardly used. Will work when plugged in to pc, but will not charge battery. I see on ebay I can purchase new...
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
Jan 22, 2011 | Sony Walkman Video NWZS615F MP3 Player
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
Sansa 4gb clip purchased will not hold charge
You should and just tell them that the battery is deffected
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Proposed solution
Creative Jukebox 3
  1. Remove the battery cover
  2. Partially remove the battery
  3. Press and hold STOP button
  4. Slide the battery back into position - the unit should power on.
  5. When the CREATIVE logo appears on the display, release the STOP button then immediately press and release the PLAY button.
  6. The following options will appear on the display:
  • Clean Up (Performs a disk scan on the players hard disk)
  • Format All (Formats the players hard disk - Note: all contents will be lost)
  • Reload Firmware (Reloads the Operating System on the Jukebox. Note: Reloading your OS, will not effect the contents of the files stored on your Jukebox Zen. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install.)
  • Reboot (Reboots the device).
Aug 16, 2008 | Creative Labs Nomad Jukebox III MP3 Player
Battery will not charge .
Dear Sir, thank you for your reply re my battery problem. I found on the net a way to remove the back cover from my ipod using a plastic set square. I check the voltage on the battery with my volt meter and found it read 3.7v and 2.2v between the red/black black
white. still the pod would not work .As I was looking at this ,my computer came up with a
window showing the itunes site , I think the window asked me to choose it as the prefaired site etc I'm not sure on the precice proceedure that I followed,but the Ipod screen lit up and all seemed normal, The down side is that I lost all my music that I had
loaded on to the Ipod, Is it possible to reactivate the lost info , or must I download from
scratch, this is the second time this has happened. I would like to thank you for your
interest and I hope to avail of your service another time. thank you.
Jul 09, 2008 | Apple iPod nano
Battery life
Hello nkikkix23,
If then iPod is still under a warranty or service contract then the battery should be covered. Even if you no longer have the receipt the store where you purchased the ipod may still be able to look up the purchase using your phone number or credit card information (depending on how you paid for the item and service plan).
I would suggest contacting the store of purchase to obtain a duplicate receipt or service contract. Once you have that information you can get service on the item to get the battery replaced.
Best Regards
"Go Ahead. Use Us."
Jun 23, 2008 | Apple iPod nano
NW-A3000 Battery replacement
1/ Remove the screw holding the back of the player
2/ Slide back cover off
3/ Remove 4 screws at the edges of the players chassis
4/ Remove battery and connector
Apr 25, 2008 | Sony Network Walkman NW-A3000 MP3 Player
i-Bulldog IMP-90 MP3 Player Logo
48 people viewed this question
Top i-Bulldog MP3 & Digital Media Players Experts
Gyula Lacz
Are you an i-Bulldog MP3 and Digital Media Player Expert? Answer questions, earn points and help others
