Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Need help replacing solonid on mercury outboard
Trying to remove solonid on 1975 merc ll5 hp motor. the out side bolt is too close to the side of the housing to get the 7/16 socket on it. I even tried a thin wall 12 point socket . Can any one tell me how to remove this bolt?
  • vmjdmitchell Jun 25, 2009
    thanks for info. it worked
  • 5,687 Answers
You may have enough room for a wrench. I have an old ignition set of small wrenches and those are slim. There is also a fitting called a crowsfoot which is thick like a wrench but short and fits on a rachet extension. The 1/4" drive set of sockets are usually shorter than 3/8th. If you have a camera, take pictures and go to Sears with it and buy something to work.
Posted on Jun 24, 2009
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
1974 40H.P. mercury outboard been setting up for 10to12yrs
This is probably a Merc 400 and you can remove the upper cowling and rope start it if you do not have the rope starter already attached. As I recall, all of this class motor were manual start with optional electric start, so thy came equipped with pull starters.
If the motor will not turn over manually then it is likely seized or frozen up and requires professional help. I have worked on numerous Mercs from 5 to over 100 HP and every one would turn over by pull starting if they were mechanically sound.
Apr 10, 2014 | Clymer Mercury 3.5-40 HP Outboards...
Need a free service or repair manual for a 20 hp mercury outboard
what u need to know i am the 20/25 merc man 20 years on 20/25 mercks
Oct 25, 2011 | Light Outboard Motor Boat Bass Fishing...
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Jul 04, 2009 | 1999 Honda XR 600 R
Bad key switch on 1975 merc. 1150 outboard
Here's something to try. There are cans of plastic coat to dip stuff into to insulate them. Then you could also try to remove the terminals and use shrink tubes on the wires and then replace the terminals. If only for a short while you can see if that fixes the problem.
Jun 24, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
190 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
