Question about Dewalt Saws
Change gear case cover DW321 - Dewalt Saws
  • David Ford
    David Ford May 11, 2010
    What is the specific question. How to do it, find a breakdown let me know and I will see what I can do.
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Dewalt jigsaw (dw321) how to change the blade
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Dewalt Saws
What are the steps to change the starter on a 1983 goldwing 1100a aspencade( any tricks?)
first step... do not pull engine...remove battery and starter connections, if you have any skid bars on the left front, remove them. remove shift peg, remove front covers on that side, remove starter bolts, pull starter out, gear will stay with chain inside cover and drop down a bit, don't be scared. If you have bought an aftermarket starter watch that the spines and gears may not match, put the matching gear in the chain inside the case and put some assembly grease to hold it center in case while you install the new starter. It does take some self control but way more easier than pulling engine.
Aug 22, 2010 | 1983 Honda GL 1100 Aspencade Gold Wing
Fluid changeing.
hello should be small cover on gear shift side of case with 3-4 screws in it , oil filter is behind cover, not many fluids to change on this bike unless it is automatic, also there is big screw in bottom of motor to drain oil.
Mar 31, 2010 | 1996 kawasaki VN 800 Vulcan Classic
Gear shifter is free floating, wont shift at all. stuck in third, i think, limped her home. primary case hot, 96 fat boy that just had belt change.
If the shaft to the foot lever snapped off inside the case, you may be able to pull the end out. It may have broken a spring between two ratchet arms the pull the shift fork drum to rotate through the gears. Pull the side cover and see if these components are accessible. If not, it means opening the transmission case to get at the parts.
Aug 21, 2009 | 1993 Harley Davidson FLSTF Fat boy
Change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Jan 18, 2009 | Saws
Saws Logo
80 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
