I have a Windows Vista Home Basic program on my computer. The Recovery D Disk is full.Can it be resized and made larger? A Adobe Flash runtime keeps popping up on my computer, how do I stop that, I've already pushed all the buttons on that Window but It still will not stay closed much more than a second. Thank You, Betty
SOURCE: error---"microsoft outlook has stopped working"
download ccleaner from ccleaner.com .
1. Remove office.
2. Run ccleaner and remove temporary files
3. Run ccleaner registry. Second Icon from the top.
4. Press scan for issues. when it will complete. Fix selected issues will be highlighted.
5. Restart the computer.
6. Install office.
If your problem is solved kindly rate the solution.
thanks
SOURCE: Internet Explorer 8 crashing when I login to facebook. Help pls!
Try checking what addons are running in IE, it could be a Software conflict , aslo update flash/java/shockwave
also, try loading the page through a proxy
https://cowclock.com
you can use the firstbar but it disables client side scripting
Glype works pretty well and CGI is java re-rewrighting
good luck!
SOURCE: my computer keeps freezing up & the runtime is always popping up
plz update the antiviruse and try again
SOURCE: I have both IE8_64 AND 32 Bit on my WIN7
Trick: Open up IE or any browser fully stretched > then restart PC while browsers are kept open. It works for me, Im not sure with yours...
Testimonial: "Thank you very much for the info. It put an end to my aggravation. Works fine now. Thnx Corefire"
SOURCE: adobe shockwave flash player crashes using XP,
Here is a complete guide to fix Shockwave Flash Crash, follow the link below:
Shockwave Flash Crash Fix
