Question about Pioneer VSX-D509S Receiver
I turn on my Pioneer VSX-D509S 5.1 surround amp comes on for a few seconds and then it says "powering off"... and shuts off
  • goldinquartz Jun 29, 2009
    pioneer vsx-d509s i disconnected all the speakers and same problem "powering off"
    President:
  • Pioneer Master
  • 1,114 Answers
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Posted on Jun 24, 2009
  • Frank Fulton
    Frank Fulton Jun 29, 2009
    It needs to be serviced. Then once it's serviced, check all your speakers and wires for shorts, unless this happened during a storm or power outage. If you don't have a good in line current conditioner/surge, get one. You more thank likely have a bad power supply, transformer, & or chipset.
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
The HDMI light on my receiver is flashing. The power button does nothing, and no other inputs do anything. There is nothing on the screen, and neither of the knobs do anything. I unplugged it for a...
For model vsx-523-k with HDMI light flashing.... PLUG THE UNIT IN AND WITH THE HDMI LIGHT FLASHING "PRESS THE POWER AND THE AVANCED SURROUND BUTTON SIMULTANEOUSLY. .. AND HOLD FOR 5 SECONDS this clear the error. .
Aug 22, 2013 | Pioneer VSX-523-K 5.1 Channel AV Receiver...
How to 'fix' a Pioneer VSX-D509S that stopped working when we lost power to our house. Suggestions?
Try holding down the advanced surround button and power button. If the unit locked itself into protect, this should clear it.
Jan 03, 2013 | Pioneer VSX-D509S Receiver
We received the vsx d509s from our son, he hooked it up, and we were enjoying our surround sound in connection with our tv. However, when I hooked up the cd player, all the speakers worked fine, but now...
It is possible that you have switched it from a surround mode to stereo mode. Instructions on how to select a sound mode begin on page 36 of the manual, which can be viewed at the link below.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033275.pdf
Jun 27, 2011 | Pioneer VSX-D509S Receiver
After a few seconds it says power off and then shuts off
hi,
remove all the speakers connected ur receiver . and try again. if working properly with out speakers . any of ur speaker have some problem. if problem remains, the amplifier side of ur av receiver is faulty. that's why it protecting and goes off. fist check it without speakers and conform.
ok
Dec 17, 2010 | Pioneer VSX-D509S Receiver
Pioneer vsx 5900s cuts out when turn volume up
most amps do that if too high in volume.but check yr speaker ratings and connections
Jul 04, 2010 | Pioneer VSX-D509S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Aug 02, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Pioneer VSX-D509S Receiver Logo
631 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
