Question about Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor
Foot pedal stuck or something won't move when try to push foot
Foot pedal stuck or something won't move when try to push down. Notice to cables on backside one seems lose
3 Suggested Answers
  • 3 Answers
SOURCE: Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • 8 Answers
SOURCE: hard foot pedal
On the base of the foot pedal there is a tensioner for the cable. Try loosening or tightening that first. If you still have the manual from when you bought it, it is explained in deatil in there. It's a common issue - not to worry!
Posted on Sep 10, 2009
Chevy venture 2004 stuck parking brake
Slide under at the rear of the back axle and pull the ebrake cable back off at the center of the axle,then push the cables into each of the rear wheels to release.
Jan 15, 2017 | 2004 Chevrolet Venture
Its a Miele Rotary B890D model, when appliance is switched on the heater plate moves up and down (automatically)without the foot pedal being pressed, seems to be that the foot pedal is stuck in a pressed...
I am by no means an expert. I have an electronic background. I have been looking at my mother in laws iron and noticed a few things about it. Check the foot pedal switch. it is easy to acess. Lay machine on its back and remove the two screws and the cover. If you have a continuity test just make sure the switch changes states when you push it. Hope this helps
Mar 03, 2014 | Miele Rotary B890 Iron
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
93 thunderbird e brake stuck rear drum brakes push to release ipush pedal goes down but gear does not release above petal
Probably a stuck shoe - may have to cut the cable to the drum to release or loosen the shoes from the backside.
Could also be a rusty cable between the foot pedal and the drums.
Jun 26, 2012 | Cars & Trucks
I have an old Pfaff 90 Sewing Machine, largely mechanical. However, I seem to have run into an electrical problem. I was just sewing and pressed down the foot pedal and when I raised my foot, the needle...
I am pretty sure it is the foot pedal. It will need to be repaired. You might want to blow air inside to get rid of dust. The bottom usually slides to the rear. You can blow out all of the parts. You may want to slightly tap your foot pedal on the floor. Remove the thread first though. You may find that it will stop when you do this. Anyway, repair or replace.
Mar 24, 2017 | PfaFF Sewing Machines
Parking brake cable is broketn, how to release the break>
Unless the brake cable is caught on something under your truck then they are already released.When you push the pedal down you pull on the cable engauging the P brakes,when you release the bakes you take tension off.
Jan 20, 2010 | 2002 Chevrolet Tahoe
CLUTCH STUCK
try fitting a new cable the old one can be sticking in the casing these cable"s do have problems with worn inner cable tubes
Aug 08, 2009 | 1986 Volkswagen Golf
Trouble with shift
could be shift interlock cable/solenoid
Aug 02, 2009 | 2006 Chrysler 300
Emergency brake foot pedal not working
Sounds like the cable is stuck also check the catch on the foot pedel
Mar 13, 2009 | 1999 Chevrolet Blazer
My gas pedal is sticking
Check the bushes at the top of the pedel. Also check the cable and replace the cable if it is not serviceable. Adjust as recommeded by VW.
Oct 30, 2008 | 2002 Volkswagen Passat
Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
579 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
