Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 1996 crafsman riding mower that we bought used and the deck wasn't properly mounted-I need a diagram of the mounting --rods etc as I'm not quite sure how they were originally attached. Thank you Clint
  • 376 Answers
Go to... http://www.searspartsdirect.com/partsdirect/index.action enter your model number that's under the seat (should start with 917), hit search, then scroll down the Subcomponents list to find what you need.
Posted on Jun 24, 2009
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
I need a diagram to mount cutting belt for Craftsman Lt100 - 21 Hp Model 917.27352
There should be a diagram on the mower deck,or sometimes under the foot rest of the mower,otherwise it's off to Sears web site for a manual !
Apr 20, 2013 | Mtd Gold 42" Zero-Turn Mower -
I need a dyagram for the mower deck of a 42in cut 14.5 hp crafsman riding mower
my craftsman has a diagram on the bottom of the foot rest look under the mower
May 04, 2012 | Craftsman Garden
I need to know where the rod arm bypass goes on a husqvarna
Are you referring to the "tension rod" on the mower deck? I think the rod you are talking about is number 114 on the diagram. Take a look at this diagram.
Oct 01, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
