Question about ViewSonic VPW450HD 42 in. HD-Ready Plasma Television
Macwynn tv blacking out
Keeps going blank like its over heating, even if we put a fan on it to cool. comes back on for a few then blacks out. please help
Cleaning inside the cabinet. (and there wasn't a lot of dust). and clean connections.
Posted on Oct 10, 2010
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
I had my camera in my purse and when i took it out and turn it on. my camera turns on white screen but with a black liquid spot on it. is it fixable? please help my camera is brand new.
Your purse would have happened to be black and the camera on the outside pocket would it?
If so and it was in heat then the LCD screen has super heated, it might come back after a few hours to cool. There is operating temperature ranges listed in the manual extreme heat and cold will just kill most digital point and shoot type cameras, sometimes they come back sometimes not.
I would also take the battery out of it and let it sit for a few hours to cool DON'T put it in a cold place let it come up to room temperature gradually.
Apr 12, 2011 | Cameras
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
TV cuts itself off
It may be overheating. Check the temperature with your hand by placing it over the fans/slots to feel for any excessive heat. If it won't turn back on until it cools, then it's a heat issue. You could help that out by using fans to circulate the air around the unit, trying to keep it cool by moving the hot air released from it and pulling in cooler air. Other than that, there may be a short somewhere, or maybe even a broken fan.
Jun 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
1996 toyota hiace disel engine. it overheating I inspected the hoses, radiator,water pump, to see if any water coming out but non, expect the recovery bottle outlet hose, water comeing out of it. it run...
if the water in your radiator or reservoir is boiling means your cars engine auxilliary cooling fan is not perfectly working enough to dissipate heat inside the radiator( heat exchanger) check cooling fan if its silicone oil filled if its rotating free and no resistance then remove fan and refill silicone oil/ if its equiped with electric fan then fan motor is busted
Apr 07, 2010 | Toyota Passenger Cars & Trucks
My tv turns on properly but after a few minutes it goes blank
you are having a heat related issue and the component or parts are failing. using a hair dryer blowing into back of set will make it black out and a portable fan should cool it enough to come back on. unless you know a good cheap tech, repairs are costly. i left the business when t.v' s became disposable.
Sep 21, 2009 | Panasonic CT-32D10 TV
2002 pt cruiser overheating was told i need a new raditor and thermostat for 1 grand sounds fishy
Flush rad & change coolant & thermostat. Check operation of rad fan, & make sure it is coming on when engine reaches normal operating temperature. Be sure to bleed air out good when refilling rad/cooling system. Start engine & turn heater on when refilling & let rad fan come on & off at least 2 or 3 times before putting cap back on rad, and refill rad as needed as you do this. then fill return bottle to proper level & see what happens.
Jun 27, 2009 | 2002 Chrysler PT Cruiser
Black rectangle block will not go away on pc monitor[top right]
hi your problem is caused by heat and a faulty power switch board in front which is also connected to usb and front audio first the heat problem download program fan control I8kfanGUI this program is free fan control set you fan speed to max to cool cpu dell made bad design on cooling. net you have to set bios on pc to auto power on pc after power loss unplug pc do not power off by windows now disconnecgt the ribbon cable that connects to front power switch plug pc back in and it will auto boot.pc should have no more problems the little board in front is faulty and dell e510 all have this problem unfortunately you lose usb ports but you get system stable again.
Apr 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
HELP OTHERS LG32LC7D FLAT PANEL TV
MOST LG PROBLEMS HAVE NOTHING TO DO WITH THE INVERTER BOARD AND THE INVERTER BOARD WILL NOT CAUSE THE PICTURE T FREEZE. THE 2 MOST COMMON PROBLEMS ARE THE POWER SUPPLY BOARD ( DEFECTIVE CAPACITORS) AND THE MAIN TOTAL ASSY. THE DESCRIBED PROBLEM ABOVE OF PUTTING A FAN ON THE UNIT IS A TEMPORARY FIX. REPLACE THE MAIN TOTAL ASSY.
Sep 29, 2008 | LG 32LC7D Television
Open Questions:
See all ViewSonic VPW450HD 42 in. HD-Ready Plasma Questions
ViewSonic VPW450HD 42 in. HD-Ready Plasma Television Logo
172 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
