Question about Samsung ML-2510 Laser Printer
No longer printes perfectly horizontal on forms, now left side ok and right side drops down a little
  • 88 Answers
Sounds like toner smear. The causes can be:
1. The weight of your paper exceeds the recommended paper weight for your printer.
2. The inside of your printer needs to be cleaned.
3. The toner cartridge is empty and needs to be replaced.
To correct this problem, try the following steps in order. Between each step, close the printer or make sure it's closed, turn it on, and then print a test page to see if the problem has been corrected.
1. Use only the recommended weight paper for your printer. Samsung recommends the following paper weights: 16 to 24 lb. (60 to 90 g/m2) for the main paper tray with multi-page feeding and 16 to 43 lb. (60 to 163 g/m2) for the manual tray and for the tray with single page feeding.
2. Clean the inside of your machine with a moist cloth to remove any dust or dirt inside. Note: DO NOT spray water directly into the printer. Spray the water on a cloth, and then use the cloth to clean the inside of the printer.
3. Replace the toner cartridge.
Posted on Jun 24, 2009
Tip
Solving printing problems in QuickBooks
If you are having problems printing in QuickBooks, follow these simple instructions to set up your printer correctly.
Open QuickBooks
Go to "File" at the top left side of your screen & click on it
This will open a drop down list
Choose "set up printer" & click on it
This will take you to a list of forms printed in QuickBooks
Choose the form you want to print & click on it
This will take you to a place to choose & set your default printer
Find the box that has the current default printer in it & look for the arrow
Click on the arrow next to the box with the printer name
This will give you a drop down list of printers to choose from
Find the name of your printer on that list and click on it
Then save your choices by hitting "ok" and closing the box
Repeat these instructions for each form you wish to print in QuickBooks.
on Sep 09, 2010 | Intuit QuickBooks: Premier Manufacturing &...
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Picture fluctuates in size
its possibly some connections in the horizontal output circuit or a capacitor failing causing this
if you have some tools soldering station ect and a little know how you can most likely handle this problem
Oct 27, 2009 | RCA D52W23 52" HDTV CRT TV
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
HORIZONTAL BANDING IN MY PRINTS
OK Guest - I'm sorry you aren't prepared to respond, so here's the best I can do without it.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Mar 16, 2008 | Epson Stylus RX500 All-In-One InkJet...
Samsung ML-2510 Laser Printer Logo
91 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
