Question about Dell Photo 964 All-In-One InkJet Printer
THE PRINTER IS NOT RECOGNIZING THE BLACK AND WHITE CARTRIDGE WE JUST HAD REFILLED
Well, you've answered your own question....take it back...lot's of junk refillers out there.
Posted on Jun 25, 2009
Recognizing recycled ink cartridges
It is likely that the cartridge was not reset correctly when it was refilled. Return it to wherever you got it from for a replacement one.
Oct 15, 2014 | HP PhotoSmart 7515 Wireless Multifunction...
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
I just put in new ink cartridges and the color will print but the black won't print comes out blank?
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer cartridge refill problem
When a cartridge is filled with non-standard ink, the printer will stop recognizing the cartridge.
Jul 31, 2009 | Office Equipment & Supplies
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
The printer is not recognizing the black ink cartridge I put in. It only recognizes the color cartridge.
IS it refilled cart if yes then you need to use the original cart from Lexmark...
Good luck..
Jul 15, 2008 | Office Equipment & Supplies
Dell Photo 964 All-In-One InkJet Printer Logo
105 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
