Question about Garmin nuvi 885T GPS Receiver
My garmin is locking up
My garmin 885 is locking up
  • 2,200 Answers
There is a reset button on your garmin which you will find recessed into the case of the unit. You need something like the nib of a pen to be able to depress it. You can try depressing it and hold it in until it begins and then cycles through the reset process.
You may find that this resolves the problem of locking up.
Hope this helps.
Posted on Jun 24, 2009
  • Radio Code Pro
    Radio Code Pro Jun 24, 2009
    *****Correction******
    According to the manual for this particular model you can reset the unit by sliding the power key to the left and holding it there for a minimum of 8 seconds.
    You can also reset it by removing and then reinstalling the battery.
    Apologies for initial information as that only applies to other models. The manual for your model can be found here (Same as 805)
    http://www8.garmin.com/manuals/nuvi855_O...
I have lost my instructions for my Nikon coolpix 885 camera
You can download a copy of the manual at
http://www.nikonusa.com/pdf/manuals/coolpix/CP885man.pdf
Sep 16, 2011 | Nikon Coolpix 885 Digital Camera
How do I reset my garmin 885? I would like to reset to the original stage. Please help.
This procedure has been known to (but doesn't always) delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites)
Power the unit off. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. Reset all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
Mar 11, 2011 | Garmin nuvi 885T GPS Receiver
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
http://www.amazon.com/Toslink-Digital-SPDIF-Optical-Performance/dp/B001ENJ3ZA
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
I have a Garmin 885 the sceen does not work. touch keys do not work. I cannot get past the Garmin start up when plugged in . when I unplug it I get the warning page and select ok and get pge with wheree ti...
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
Ihave Garmin nuvi 885. Suddenly screen is frozen. I start again and tochscreen work a few clic and screen is freezing again. I thought battery poblem and I purchase extra battery and arge fully and I tried...
You can update it with garmin webupdater or If its still under warranty send to garmin to be refurbished.I have the same unit and it does freeze up momentarily while the proccessor catches up.Only for a second though.Its a refubished unit as well.
Dec 23, 2009 | Garmin Nuvi 660 GPS Receiver
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Nuvi 855T locks up 10-15 seconds after power up
Email correspondence from Garmin tech support:
"Thank you for contacting Garmin International. We had an announcement
today that there will be a software update to address this issue coming
out within the next week. This is an issue we have found to be affecting
a large amount of 885 and 855 units. Please try the WebUpdater again
after next Tuesday to see if the update has been released. With the
update, your unit will be back to normal. Please let me know if there is
anything else I may assist you with."
I think the solution is obvious: Return the Nuvi 855T and get my money back.
Jun 24, 2009 | Garmin GPS
Garmin nuvi 885T GPS Receiver Logo
534 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
