Question about Lexmark T644 Laser Printer
Lexmark T644 stopped printing. Print queue says error processing command.
PABLOCSA
  • 1124 Answers
SOURCE: prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
guide2u
  • 461 Answers
SOURCE: Lexmark E120 does not print
Check your driver is correct for your XP OS... below link might provide you some information to help resolve your issue
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
Posted on Nov 01, 2008
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
Roop1980
  • 228 Answers
SOURCE: Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Posted on Apr 17, 2009
  • 70 Answers
SOURCE: document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
Posted on May 28, 2009
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Hi. My lexmark z640 printer has stopped working. When i double click the z640 icon on the desktop the window opens and says that the current job is deleting, this has been like this for hours. tried to...
Try to clear the print queue first before sending a new print job. Follow these steps to clear print jobs stuck in the print queue(for Windows):
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder
3. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 27, 2011 | Lexmark Z640 InkJet Printer
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
I HAVE A LEXMARK 5690 AND THERE IS A PRINT JOB STRUCK IN THE PRINT QUEUE AND I CAN'T GET IT TO CANCEL. THE OTHER JOBS AFTER THAT WILL CANCEL BUT TO FRONT ONE IS STUCK. AND I CAN'T PRINT ANYTHING AND I...
1. Go to Start, Control Panel and Administrative Tools. Double click on Services. 2. Scroll down to the Print Spooler service and right click on it and select Stop. In order to do this, you need to be logged in as Administrator. At this point, no one will be able to print anything on any of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:\WINDOWS\System32\spool\PRINTERS. Delete all the files in this folder. This will clear all print queues (it’s a good idea to first make sure there are no other print jobs being processed on any of the other printers on the server because doing this step will delete those jobs also)
Sep 01, 2010 | Lexmark Office Equipment & Supplies
Printer document in queue will not delete
Dec 20, 2008 | Canon PIXMA MP460 All-In-One InkJet...
I have a lexmark t644 printer and have an error code of 900.44 any ideas on how to fix this
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Nov 17, 2008 | Lexmark T644 Laser Printer
Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Jun 27, 2008 | Lexmark T644 Laser Printer
Lexmark T644 Laser Printer Logo
220 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
