Question about Porter Cable 9845 Saw Boss 6" Cordless Circular Saw
9845 will not work, was fine now dead - Porter Cable 9845 Saw Boss 6" Cordless Circular Saw
  • 3 more comments
  • ronaldhof847 Jun 24, 2009
    tried all that but don't know how to check the brushes, would the go bad from one second to the next
    at a parts store their is no listing for brushes
    there is no access to the brushes, that I can find
  • ronaldhof847 Jun 25, 2009
    if you go here you will see no part listed as brushes of any kind
    http://www.ereplacementparts.com/porter-...
    Comment posted on Jun 24, 2009
    tried all that but don't know how to check the brushes, would they go bad from one second to the next.
    Comment posted on Jun 25, 2009
    Top Expert:
  • Porter Cable Master
  • 80,668 Answers
If no brushes are listed they are liftime and no replaceable, so that means u either have a power tool repair shop use generic brushes or u replace the tool.
Posted on Jun 25, 2009
    President:
  • 2,923 Answers
You need to isolate the problem. Please check the following:
1. Battery - make sure that the battery is fully charged. Try to remove the battery and put it back after 3 minutes.
2. Hole to the battery - do not allow foreign matter to enter the hole for connecting the rechargeable battery.
3. Check the saw blade
4. Mounting screws
5. Carbon brushes.
If there's a problem with the following parts that I advised you to check, the saw might not work.
Hope it helps and have a good day!
Posted on Jun 24, 2009
  • 2 more comments
  • Melvin Ramos
    Melvin Ramos Jun 24, 2009
    Please check the link below and it might help:
    http://www.hitachi-koki.com/manual_view_...
    Thank you!
  • Melvin Ramos
    Does your circular saw has a lock button? If yes, you need to check it and the belt as well.
    Check the user manual and get the exact part number of the carbon brushes for your equipment. You may check the link below for the carbon brushes:
    http://www.solenttools.co.uk/table-saws/...
    Let me know if you need anything else. Thank you so much!
  • Melvin Ramos
    Melvin Ramos Jun 25, 2009
    I'm sorry, I tried searching for another possible cause of the problem but I couldn't find it aside from those steps that I have provided you earlier. I couldn't even find the exact user manual of it.
    The best thing that I could suggest is to contact the manufacturer for second opinion.
  • Melvin Ramos
    Yep, I checked it out and there's no carbon brush listed. This is different than what I have expected. The things that I have advised you to check are the only things that I could think of the possible cause of the problem.
    I believe that you may need to consult other fixya expert's opinion also. I do apologize.
CDE-9845 power up my MRP-M500 amp but subs wont work?
Have you checked the subs? And tested the RCA cables?
Mar 20, 2012 | Alpine CDE-9845 CD Player
How do you set minutes on clock?
Settin Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
6. To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
Mar 11, 2012 | Alpine CDE-9841 CD Player
How do i set the time on my alpine cde 9841?
Setting Time
displayed.
• To synchronize the clock to another clock/watch or radio time
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Jun 17, 2011 | Alpine CDE-9841 CD Player
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
Alpine CDE-9845, no audio from cd's either normal or mp3. Tuner works fine. Where to troubleshoot?
You have the wrong blue wire connected.
Your power antenna wire is hooked to the amp remote wire and vice versa.
Your radio thinks the tuner is off - and is dropping the signal thru the power antenna wire - and turning off your amplifer.
Switch the 2 blue wires in your install - and you'll be all set.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 06, 2010 | Alpine CDM-7874 CD Player
How do i connect and play my ipod through my cde-9843
look at the back have an aux input if not you have to get a fm modulator and let some one put in for you
Jun 22, 2009 | Alpine CDE-9843 CD Player
AUX to work
Hello alex_maya21,
The AUX input on your CDE-9845 is on the back of the receiver. To use it, you need a cable with the appropriate connectors on each end. The receiver end needs to be a standard "mini plug" and the device end needs to match the output connector on your mp3 or iPod. There are many commercially available cables that you can plug in and run the device end under the dash to a convenient location. Almost any car audio retailer will have the correct cable or you can order one online from www.crutchfield.com.
Hope this helps.
Jun 21, 2009 | Alpine CDE-9845 CD Player
Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
displayed.
only) or press
only) or press
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
Apr 26, 2008 | Alpine CDE-9843 CD Player
CDE-9845 is not turning on or doing anything.
The only way to know for sure is to see if it has voltage getting to it. You need a Voltage tester (DMM, testlight, etc...). There should be 12 volts on the yellow always and on the red wire when the Ignition/Accessory is on. If both are present then the radio probably got surged and will have to be replaced/repaired.
Sep 09, 2007 | Alpine CDE-9845 CD Player
Porter Cable 9845 Saw Boss 6" Cordless Circular Saw Logo
79 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
