Question about Craftsman 1 Hp, 4 Gal. Air Compressor
Motor comes on, but air pressure does not go up.....will never get above 20 lbs of pressure
  • 146 Answers
You have to adjust the regulator usually turning clockwise increase the pressure.
Posted on Jun 26, 2009
1988 Nissan 300ZX oil pressure only 15-20 lbs
A failed oil pressure switch-- most likely
I would verify the pressure with a mechanical
gauge on motor--- then replace the press sw
Dec 01, 2012 | Cars & Trucks
Air conditioning blowing warm air
if the cooling fan is not coming on the high pressure switch will shut it down check that
May 21, 2012 | 2005 Kia Spectra5
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
Craftsman pro mod# 919167770 , oilless air
Check to be sure your drain valve under the tank is turned completely off first
Mar 12, 2010 | Air Tools & Compressors
2001 ford focus zx3 starter replacement instructions
2.0L DOHC Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Air cleaner outlet tube
    • Lower starter motor bolt
    • Two starter motor upper bolts
  3. Slide the starter motor from its mounting until you can gain access to the wiring.
    • Integral connector
    • Starter motor
To install:
  1. Install or connect the following:
    • Integral connector and tighten the retaining nuts to 61 inch lbs. (7 Nm)
  • Starter motor to its mounting
  • Two starter motor upper bolts and tighten to 15–20 ft. lbs. (20–27 Nm)
  • Lower starter motor bolt and tighten to 15–20 ft. lbs. (20–27 Nm)
  • Dec 06, 2009 | 2001 Ford Focus
    WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
    Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
    Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    I have a model C48A93A06 1/2 horse power pump motor and it pumps water fine,but, it will get within 2lbs of the cut off pressure and just sit there and run and will not cut off unless I bump the pressure...
    I would check the holding tank pressure, if you have one with a bladder. Turn electric off to the pump, and drain all water from the tank. Take a tire pressure gauge and check the tank pressure at the air valve on top of the tank. That pressure should be two lbs less than your cut-on pressure. If the cut-on pressure is 20 lbs, then the tank pressure should be at 18 lbs. If there's too much pressure in the tank, it wont let the pressure switch work correctly. If you get water from that air valve, then the bladder is ruptured, and a new tank is needed.
    I hope this works for you!
    Aug 09, 2009 | Plumbing
    Husky comp on 1st start builds up 75 lbs and wont restart
    Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
    Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Air in rear shocks
    Depending on your weight and if you carry a passenger as to the air pressure. I normally run about 14 but 24 if riding 2 up.
    Recommended pressures:
    up to 150 lbs- 0
    each addition 25 rider pounds > 150 lbs add 1.0 lbs
    each additional passenger pounds > 150 lbs add 1.5 lbs
    each additional 10 lbs of laggage add 3.0 lbs
    Max Pressure 35 psi
    Nov 10, 2008 | 2002 Harley Davidson FLHT Electra Glide...
    Craftsman 1 Hp, 4 Gal. Air Compressor Logo
    177 people viewed this question
    Top Craftsman Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
