Question about Edimax Computers & Internet
How do you connect cables to the back of a KVM switch. I have 2 pc's and want to use the Mini Genie KVM switch. What cables get connected to the Console? and what cables get connected to the PC1 and PC2 ports. Both PC use ps2 type connectors for the Keyboard and mouse. The Switch came with a Cable that has male VGA connectors on both ends also attached to each VGA connector, there are 2 ps2 connectors for the keyboard and the mouse. Thanks
2 Suggested Answers
  • 31 Answers
SOURCE: I am trying to run two pcs using an EDIMAX 2 port
i don't ?
Posted on Jan 09, 2010
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV GenieĀ® WiFi Setup & Connection ' DIRECTV ...
    DirecTVWatch this video to learn how to connect your GenieĀ® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
Feb 08, 2016 | Televison & Video
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
I have a d-link kvm-121 connected with 2 pc desktop when both pc is on 1 of the pc will see the shadow of another pc and then i tried to plug off the vga cable of one of the pc there are no more shadow....
The D-Link 2-port PS/2 KVM Switch with Audio Support(KVM-121) allows you to .... docking station and a Dell desktop, using a logitech PS/2 mouse and keyboard. ... as it easily allows me to connect another computer when I'm troubleshooting problems. ... See the nine (9) Hot Keys on page 9 of the superbly written and ... › ... › Cables & InterconnectsKVM Switches - Cached - Similar
Jun 30, 2010 | D-Link KVM-121 2-port KVM Switch
IOGear (GCS632U) 2-port KVM Switch problem. All functions well it seems after connecting for first time Mac Mini and XP Windows Dell PC except when switching to Mac I get a blank dark screen. Another side...
The IOGEAR GCS632U is designed to work with VGA computers and monitors. Using the Mini DVI to VGA adapter is not guaranteed to work with this KVM switch.
The Mini DVI to VGA adapter can only convert the port, but it does not have an ability to convert the signal from digital to analog when it's connected to the KVM switch.
What you need to have is a DVI to VGA SIGNAL converter. Unfortunately, I don't have a model number handy, so I would suggest to contact IOGEAR, because I'm sure that they already have a work around with this issue.
Thank you and good luck!
Oct 11, 2009 | IOGear GCS632U 2-port KVM Switch
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Wobbly screen on mac laptop
are you using a Mac Mini-DVI to DVI adapter or any adapters? This is a VGA video output type of KVM switch so probably the problem is with the adapters involved to it.
Nov 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
How do I hook up a Belkin 2-way Switch with Audio Support and Cabling?
kvm switches are easy, they just dont look it with the number of sockets.
hook up your keyboard monitor speaker mic mouse cables to the output sextion of the kvm just as if you were hooking them to a single pc.
hook the cables from the pc-s as if the kvm switch were the peripheral devices,
so that all the outputs from pc 'A' are connected to the relevant inputs on 'A' side of the kvm,
all the outputs from pc 'B' are connected to the relevant inputs on 'B' side of the kvm
Jun 26, 2008 | Belkin F1DL102P 2-port KVM Switch
Belkin KVM 2 port switch
Sounds like its not detecting video on the 2nd port. Have you tried switching the computer on port 1 to 2 yet? If the problem moves then I would suspect that computers video card or the cable that connects it to the KVM. Let us know what happens or if you need more assistance.
Jun 26, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
