Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Tv light truns on green and then the red power ligh starts blinking
  • George Lovato
    George Lovato Aug 02, 2013
    TY for your advice.After reviewing your salution I decided to do more troubleshooting and found that the bulb on the left side was burnt out.I.m thinking it was caused from the power surge we had.Thanks again
  • 261 Answers
It might be a issue with the power supply, do you hear any strange noises or do you see any other led warning light?
Posted on Jun 24, 2009
    New Friend:
My problem was caused by a power surge.TV went off and then came back on and burnt out the bulb located in the left rear panel.(Under the warning panel).
Posted on Aug 02, 2013
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
My tv turns for a couple of minutes then truns off by itself...the red light blinks on and the green light that say timer and lamp also blink...help how do i fix it?
The projection lamp on this tv,when was it was last change?The last time change was about 1 1/2 or 2 years,and tv on an used at 4 or 5 hours a day.The lamp life is over,require a new projection lamp.
Jul 10, 2010 | Akai PT61DL34 Television
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Laptop Compaq N610C did not powered ON
Remove your battery - start the unit on A/C then after booting up refitted battery.
Jan 21, 2009 | Compaq Evo N610C Notebook
Sir, When i Trun On the Laptop, N610c the charging (cell) ligh blink 4-6 times. but laptop did not start i put it on charging by connecting it with charger charging light turn on contineously and when i...
Remove your battery and install the a/c connector - power the unit up then when inside windows refitt the battery - examine the condition in control panel >> power options >> you may have a dead cell in the battery.
MY TV
IF it's blinking it's probably an error code. If you have the manual see if it says what it means. If not, post the blink sequence here, maybe someone knows what it means.
Dec 05, 2007 | Televison & Video
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
183 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
