Question about Xerox WorkCentre XD105F Laser Printer
I have a Xerox WorkCentre XD105f laser copier.
I replaced the drum. Now I get CH error which means insert toner.
However I already inserted the toner and reinserted it. I know the toner still has enough ink. I turned the copier off for 20 seconds and then on again but I still get the CH error.
  • 4 more comments
  • David2010 Jun 24, 2009
    I unplugged the power, waited 20 seconds, and reinserted the toner and the drum. I still get error CH which is now blinking.
    According to the manual, the CH error stands for
    "install the toner cartridge".
  • David2010 Jun 25, 2009
    The tab on the toner hopper is at the back of the toner cartridge breaks??
    I do not see a tab.
    What is a "breaks"? What is a toner "hopper"
    Yes a larger diagram would help.
    What is the "main pwb"?
    How do I set settings back to factory default settings?
  • David2010 Jun 26, 2009
    Knocking on the toner cartridge made the CH error go away.
    However when I remove the toner cartridge and the drum, the CH error came back. I had to knock on the toner cartridge again to make it go away.
  • 15,935 Answers
If you are using the incorrect part number Toner Cartridge, this can cause you to get a J1 code when there is still toner in the Toner Cartridge, among other possible problems. It is possible for the incorrect Toner Cartridge to fit into your machine, and work for approximately 100 copies, then stop working. Using the incorrect Toner Cartridge can also cause possible damage to your WorkCentre.
  1. Open the Side Panel on the right side of the WorkCentre.
  2. Open the Front Cover.
  3. Pull the Toner Cartridge (the cartridge on the left) out by pressing down the green Release Button and pulling the Toner Cartridge out towards you.
  4. To tell the difference between an XD series and an XL series Toner Cartridge:
    • If you still have the box the Toner Cartridge came in, check the Part Number. The XD Toner Cartridge is part number 6R914. The XL Toner Cartridge is part number 106R482.
    • The XD Toner Cartridge has a "finger hole" on the front of the Waste Toner Sump; the XL Toner Cartridge does not. Look at the clear plastic box on the front of the Toner Cartridge (the Waste Toner Sump). If there is a "finger hole" on the front of the Waste Toner Sump with a screw inside of it, you have an XD Toner Cartridge.
    • The newer XL Toner Cartridges have a peach-colored Developer Gear. Look at the gears on the back end of the Toner Cartridge. If the widest gear is peach-colored, you have an XL Toner Cartridge. However, the original XL Toner Cartridges had white Developer Gears, so a Toner Cartridge with all white gears could be either an XD or an XL Toner Cartridge, so check for the "finger hole" as well.
  5. If you determine that you have the wrong Toner Cartridge for your model machine, you will need to replace your current Toner Cartridge with the correct part number.
Since toner is a powdered substance, it can sometimes settle or clump inside the Toner Cartridge and give you a CH code. Knocking on the Toner Cartridge will break up the clumps of toner to allow the WorkCentre to access the toner.
NOTE: Always hold the Toner Cartridge over a waste basket to avoid toner spilling on your clothing or floor.
  4. Hold the Toner Cartridge over a waste basket.
  5. Knock across the top of the Toner Cartridge.
  6. Reinsert the Toner Cartridge.
  7. Close the Front Cover.
  8. Close the Side Panel.
  9. Try to make a copy.
Thanks for using FixYa!!
Posted on Jun 25, 2009
  • blueextc3221
    blueextc3221 Jun 25, 2009
    Additionally - the unit must be unplugged for 5-10 minutes (not just 20 seconds) for a hard re-boot to allow internal capacitors to discharge fully.
  • blueextc3221
    Finally - a OWNERS MANUAL in PDF format for easy reference.
    CLICK HERE
    Sergeant:
  • 173 Answers
You have to clean dust near drum position.
Check your new drum has not any leakage.
Some time drum has issue.
Reset all settings to factory defaults.
Clean all parts from dust.
    President:
  • Xerox Master
  • 1,314 Answers
Here is a snapshot of the page in the service manual.
Basically, if the 2 locating pins on the back of the toner are not broken, then the main pwb is at fault:
Sorry it's so small, but fixya limits the size to 150k; hardly enough for any detail. Let me know if you need to see a larger version.
  • 583 Answers
Remove the toner cartridge
after removing it from the machine and shaking it from
side to side to loosen additional toner.this will solve the problem.
also clean the side metal parts and connections of toner cartridge.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
  • 508 Answers
Take it to an ink jet refill center they will most likely not charge you and there very knowledgable!!!
    President:
  • 2,187 Answers
When the CH is flashing the machine may not see the cartridge. Open a tab (the one that tells the machine that the cart is in) at the back of the cart breaks. The tab is on the toner hopper of the cart. If it is a steady ON, it can be either a door switc or a blown copy lamp thermofuse which can be unlikely.
This also happens when you use a sharp cartridge since the pins may be slightly not aligned.
Thanks
Posted on Jun 24, 2009
  • Nicolo Carlo Parazo Jun 25, 2009
    I could not find an exact image of the toner hopper for your unit. See the link below.
    http://www.tonerrefillyourself.com/image...
    Genius:
  • 1,689 Answers
The CH error is illustrated in the user manual as a possible incompatibility or wrong alignment. you may want to check on the drum that you have if it is an OEM.
you may refer to fixyourownprinter.com for more info.
regards,
voodoo
    Genius:
  • 1,847 Answers
Some part(developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, amd make sure they are installed and plugged in properly.
The 'CH' code will automatically reset when the fault is found
Thanks
Kevin
  • 854 Answers
This is basically a toner cartridge. You can try using other toner cartridge to differentiate. If the problem still there try to clean this area. see illustrations..
    Sergeant:
  • 353 Answers
Unplug the power for 20 seconds , reinsert toner ,then repower
  • gerald darling
    gerald darling Jun 24, 2009
    this is a page from the manual
    The toner indicator on the copier diagram will light when the toner supply is
    low. Approximately 10 more copies can be made, but you should have a
    replacement cartridge in stock. When the J1 status code is displayed, the
    machine will stop operating until the toner cartridge is replaced.
    Note:
    Ensure that the alternate paper tray
    is lowered (XD104/ 105f/ 124f/ 155df only).
    1. Press the release lever to open the side
    cover.
    2. Press the front cover release buttons to
    open the front cover.
    3. Press down on the green lever on the
    front of the old toner cartridge and pull
    the cartridge out.
    Note:
    Help the environment by recycling
    your used toner cartridge. Refer to the
    recycling brochure packed with the Toner
    Cartridge for details.
    4. Shake the new toner cartridge
    horizontally four or five times and then
    remove the cover.
    • Save the box and the cover for
    shipping.
    5. Slide the new toner cartridge in until it
    locks in place.
    6. Close the front cover and the side
    cover.
    • Wait for the ready indicator to light.
Drum error
Hi, the drum is the part where you insert the new cartridge toner, some times when you replace the toner need to clean the small filament in the drum unit, is very simple, ther is a blue part, slide 2 o 3 times and return to his original position marked with a arrow, maybe this solve your problem,9436fabb-a042-4f75-962b-c59ad843e6bb.jpg
Sep 17, 2013 | Brother HL 2140 Laser Printer
My printer MF4122 shows Toner is not set. Insert Toner. means what?
Believe it or not this error normally relates to the paper tray. Take all of the paper out of the tray and then reinsert the paper into the tray.
Hope this helps.
Sep 14, 2012 | Canon imageCLASS® MF4150 All-In-One Laser...
What is error code 2200 on Kyrocera fs-4000dn
The drum unit is jammed. The waste toner gear is jammed from waste toner hardening. Best solution replace drum unit other wise you will have to pull up the unit and clean unit thouroughly.
Usually this problem occurs if unit is used over 300,000 prints.
Feb 09, 2010 | Kyocera FS-4000DN Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
Brother MFC7440N Toner error message
It looks like the toner cartridge is not inserted correctly.
Turn of power. Remove cartridge and reinsert it in right position. Close the door correctly. Restart.
Mar 27, 2009 | Brother MFC-7440N Laser Printer
Error message "Waste Toner Full Replace The Drum" which was replaced approximately one month ago.
Open the left cover,remove the drum.you will see on the drum unit there is plastic plugs that you can remove,remove them and remove the waste toner in the dustbin.put the plugs back and insert the drum in it's place.
Dec 04, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon ir1019/1023 System Error Code E019
Waste toner full,remove drum unit and open plugs,remove waste toner,put the plugs back.Insert the drum unit again.
Oct 22, 2008 | Office Equipment & Supplies
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Xerox WorkCentre XD105F Laser Printer Logo
279 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
