Question about Digidesign Mbox 2 Barebone
How do i connect
Motif xs6 to mbox
  • Anonymous Apr 18, 2009
  • 243 Answers
Firs you want to connect it to your pc via midi or usb then spdif it to your mbox and your set... there are actually a lot of ways to hook up a motif xs6 any way in particular your looking for?
Posted on Jun 13, 2008
Motif 6. When turned on, reads 'now checking plug in broad'. What's wrong?
If you see this message for only a short period of time, then this is normal. The plug-in boards are options that you can add to your Motif 6 to expand sounds/functionality. The first thing the Motif does is do a self check on the main keyboard first, then the plug-in boards. If the message just stays and does not go away, then there could be something wrong with either the optional plug in boards, or the main board the plug-in boards plug into. Make sure the option boards have not come loose, or have become damaged. Check the option board connectors.
Mar 31, 2016 | Yamaha MOTIF XS6 Keyboard
Yamaha motif xs6 after touch problem
needs first aid by cleaning it first,,if it doesnt work faulty board that serves the keys. (mks)
Aug 26, 2014 | Yamaha MOTIF XS6 Keyboard
What kind of voltage regulator is good Yamaha Motif XF8? (-8.25% and +4.2% of 120V)
A voltage "regulator" would only limit the voltage from going above a set amount - it wouldn't do anything for a power dip. To protect against that you really need an Uninterruptable Power Supply (UPS) which would switch to battery power in case of a power dip. Do you really think you're home electrical system is that unstable? Are your problems happening in different locations?
Mar 05, 2014 | Yamaha MOTIF XF8 88 Note Workstation...
How do i record drums from drum kit
Hello nastyneph320:
Computer connectivity (via USB, Ethernet or the FW16E FireWire option) and DAW integration features like 8 zone Master mode, DAW remote control and cross platform editors let you seamlessly integrate the Motif with any DAW software, including the bundled Cubase AI software.
Translated it means that you can use USB, Ethernet, or FireWire connection to your PC and use DAW or Cubase AI software for recording. But I'm pretty sure you could use some other type of software for recording as long as it accepts your Keyboard.
Don't forget to vote with a thumbs up if this helped.
Feb 26, 2011 | Yamaha MOTIF XF8 88 Note Workstation...
Pt wont see my mbox
need driver for ct4670 sb!tnx!
Oct 09, 2009 | Digidesign Mbox External Sound System
Mbox2 mini digidesign buzzing
Are you running passive speakers if so try using a ground loop isolator this should stop any noise interferance.
Jan 22, 2009 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Protools mbox2 issue
it doesnt sound like its the mbox more maybe the protools install. But as far as the cable goes can you tell me if you can ping the mbox throught the 1394 connection. If you cant ping it then damage may have been caused to the unit and it may need to be serviced. I fix my own M-box's but in my store it only costs around $50usd to fix almost all problems with a mbox2
Sep 22, 2008 | Digidesign MBox 2 External Sound System
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
275 people viewed this question
Top Digidesign Computers & Internet Experts
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
