Question about RCA R52WM24 52" HDTV Projection Television
After i turn on my big screen tv, the light that shows that it is on just blinks 3 times and then turns itself off again. then u have to wait for a min or 2. could someone please help me out
    Problem Solver:
When i turn my tv on it is cloudy and stays cloudy please help me
Posted on Jul 09, 2009
  • RCA Master
  • 8,617 Answers
You need to replace the FLYBACK # 270125 and CP150. You can get the parts which have detailed step by step instructions at the following link
http://servicemanuals.vstore.ca/
Posted on Jun 25, 2009
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Ps3 slim turns off without showing any yellow light, it´s brand new and it doesn´t show any image on the tv screen, it takes like 20 seconds after turning it on for it to shut itself, and then...
FIRST IF U HAVE 2 HIT ANY EQUIPMENT THAT SONY MADE ITS NOT GUNNA WORK RIGHT PERIOD MANLY B/C SONY SUCH A BIG COMPANY (YES THEY MAKE OOPSIES) AND DONT MAKE SMALL ERRORS LIKE THAT ALL IM SAYIN IS BUY A NEW ONE IT GOT MEST UP IN BUILDING PROCESS OR U ACCDENTLY DROPPED IT OR SOMTHIN HOPE I HELPED
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Power problems
You have bad capacitors in the power supply.
Sep 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Cant get jumbo remote to work for my tv
If it's an Innovage brand jumbo remote, try this...
There are 2 different versions of the Innovage Jumbo remote, an old and a new.
For the old version:
1. You have to have the TV or DVD turned OFF.
2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid
3. Then press TV (or DVD) button once till it lights once and turns solid and press the ON/OFF button very slowly and repeatedly as many as 300+ times to wait for the TV (or DVD) to go on.
4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This is very frustrating but my advice is to take it slow and methodical. Think the tortoise and the hare...if you go too fast, you'll redo it several times because you'll keep passing it up and accidentally turn the TV on and off suddenly and miss the code.
For the newer version:
1. Turn the TV (or DVD) ON.
2. Press CODE SEARCH once and it blinks.
3. Press TV (or DVD) once and it blinks.
4. Press ON/OFF button only ONCE.
5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches.
6. Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have to push ENTER to lock in that code before it goes onto the next one. (which it will even if the TV is off)
Apr 25, 2008 | Big Button TV Universal Remote
Codes for Big Button Remote
If it's an Innovage brand Jumbo remote, try this...
Apr 16, 2008 | Big Button TV Universal Remote
RCA R52WM24 52" HDTV Projection Television Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
