Question about Vivitar ViviCam 5100 Digital Camera
No power I was recording a movie i turned it off an=d haven'yt been able to turn it back on my warranty is out how can i possibly get it fix
  • Isabell Nov 05, 2007
    Its seems to have no power any where what shall i do if any one can make suggestions plz reply
  • carlos277 Nov 08, 2007
    same problem, my vivicam 5100 does not turn on
Yes, my camera is working now. it works. Thanks....
Posted on Oct 23, 2008
  • 797 Answers
Here is possible fix.
Understand and be warned that doing the following may damage the camera even more, but if it does not work, then it may be worth the try.
Get a towel, fold it and lay it on a table. With the camera turned off and at an angle so that it will hit on one corner, hit the camera on it's edge on the towel. Not too hard, but do it with enough pressure so that the camera may come back by shaking up the internal connections.
Try to turn it on again, try a couple more times if the first is not successful.
What this does is to cause the internal connections and parts be shaken to such a degree as to make possible connections work again.
You have (in my experiments) about a 30 percent chance that this will work and cause the camera to come back as it did before.
If this does not work, the camera is only good for parts or repair.
Possibly to be sold on a site such as Ebay as is or for parts or repair.
Posted on Sep 29, 2008
Vivitar iTwist 975DVR keeps stopping during recording. Have to turn off completely and turn back on again then continue recording until it stops again. Please help.
try with another memoy card, if the problem persist, ask for the manufacturer technical service to fix the problem as it is still warranty covered
Nov 29, 2014 | Vivitar Cameras
DVD Recorder will not turn on.
You must check its power regualtor baord to get the fault. Sometimes, it may need replacement as card basis. Contact the nearest authorised center for pansonic.
Apr 15, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
At the power on the display is looked "welcome" and no operation is possible.I have controlled the HD and the DVD (I am a expert of electronics device). Is not possible shutdown the recorder...
Dear Cauci
I haven't a final solution for our problem. But I found a problem in the power supply. If you disconnect the CD-drive from the internal power supply and then connect to an external power supply, the recorder starts up normally.
Maybe it's help you. Please let me know, if you find a really solution.
Gianni Baiguera
Jan 02, 2011 | Sony RDR-HX825 DVD Recorder/HDD Recorder
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
When I turn my recorder on it will only stay on a few seconds and then turns off and goes back to stand by mode. Any suggestion?
Sounds Like a Power supply fault....If you have no expirence in fixing things the best thing to do is to take it back to the supplier if it is under warranty if it is out of warranty then take it to a local service centre...but if you feel compentent enough to fix it yourself you need to open up the unit (follow warnings and remeber to disconnect from mains power) and find the Power supply section which should be at the back right hand of the unit ( normally were to power cord comes into the unit) and you need to test that the front panel power switch is not shorting causing it to turn on then turn off again....there could be some goo on the contacts of the switch this is quite common. more than likely this unit uses a relay to activate the power supply when the front button or the remote power is pressed...check that relay with a multi-meter on its contacts make sure it is not shorted (it should be open if the unit is not working and shorted when the unit is turned on)..if it is still faulty then take it to a service center as it will take to long to explain on here where to go next but it might have something to do with the remote control switching or could be something wrong with an controler IC.....hope this helps,ben
Aug 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to disable microphone / sound on Samsung Digimax A503 Camera while recording movie
no i cant even turn the sound on...can sum1 please tell me how you get the camera to record sound when i record a video.thankyou :)
Jun 13, 2008 | Samsung Digimax A503 Digital Camera
Movie recording disabled... how do we fix this?
yes i also have the same problem. i had all my clips in there and i dropped my camera then i lost them and now it says movie recording disabled
Mar 18, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Stuck in movie mode, but won't record
internal microswitch connector has been it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
