0xa0000002 I have the same problem.... It says Restore Failed - reason 0xa0000002. Click OK to restart the computer. I used a restore disk.
    Sergeant:
    Champion:
  • 253 Answers
Hi this error generally caused by corrupt partition . recreate the two partitions (FAT 32) ,by adding the right names, and then use the CDs.
Posted on Jun 24, 2009
Error message "restore failed 0x00000070"
Step 1:
Which operating system ?
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings. Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard, mouse or monitor. Click the Windows "Start" menu and choose "All Programs." Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab. Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default." Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process. Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Mar 10, 2013 | Computers & Internet
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 23, 2012 | Computers & Internet
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
Acer 5100.  During a Full Restore this error message interupts the restore: (The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install...
Since you cant start it using your recovery disk, you need to bring it to a service center because the are going to take out the hard drisk and connect it with other computer so they can do the restoration or reformating
Nov 08, 2009 | Acer Aspire 5100 Notebook
Need help,, windows 98.how do i restore
boot with the Windows 98 cd in the drive and go to dos, enter chkdsk /r to repair and restore system files.
If you are having a specific problem it might help to know more exactly what you are seeing.
Aug 31, 2009 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Restore problems with acer 5920
Your Restore Partition Has Either Been Altered Or Is Missing....
You Will Need A Full Version Operating System Disk To Install
Feb 06, 2009 | Acer Aspire 5920-6727 Notebook
Acer Restore
The recovery partition is corrupted. 1st option is, You can send your computer to acer repair center in germany. I believe acer have international warranty. 2nd option is to buy the recovery cd from acer, you can installed by yourself.
About downloadable OS, i don't think they have it online.
Feb 24, 2008 | Acer Aspire 5100 Notebook
Trying to restore my system
Just use original OS and repair OS
Dec 07, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
368 people viewed this question
David Payne
David Payne
