Question about Insignia IS-DVD1001 DVD Recorder/VCR
I have the samne problem, hoiwever when I press the menu/setup button it says setup on the display but nothing changes on the tv, it does not have a navigation menu, any suggestions on what to do to remove the progressive scan from my screen
Posted on Apr 08, 2008
  • 113 Answers
Click setup button and navigation with arrow to this spot.
Posted on Mar 01, 2008
0 characters
3 Points
My DVD player LG DR165 DVD Recorder is giving me an error.
PROGRESIVE SCAN will only work with an HD TV and it does not work via the scart lead. Select off for it if you have an old TV. If you can't get it to stop coming on by doing what it says to do, then you have an electrical fault on the LG.
PROGRESIVE SCAN itself is a method of getting high quality images on HD TV's via the special sockets at the back of the DVD.
Mar 30, 2009 | LG DR-4810 DVD Recorder
I put my dvdr phillips recorder on progresive scan no picture
You will have to reset the DVD player in order to undo the progressive scan option. Since you cannot see a menu to do so...
1. Unplug the dvd player from the outlet
2. Press and hold down the STANDBY-ON m button on the front of the Recorder while reconnecting to the power outlet.
3.Release STANDBY-ON m when '  ' appears in the display. All the information stored in the memory (programs, time, TIMER) will be reset (cleared).
Hope this helps with your problem, thank you for stopping by Fixya! Please leave a positive rating if this solution works for you.
Mar 15, 2009 | Philips DVDR615 DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
How to turn off the progresive scan
This is frustrating but what worked for me:
1. first make sure you are on CD/DVD mode
2. select the 'Setup Menu' button so that the words 'Setup' appear 3. press the 'CH/TRK Stop' button (it is blue on my remote) and hold it down (approx 5 seconds) - if it works, the setup menu will be displayed.
If this does work - write the instructions on a small index card and glue it to the DVD player ;>P
Dec 21, 2008 | DVD & Blu-Ray Players
Dvw-7200: no picture on the dvd
My dear friend I think you maybe by mistake put the function progresive scan on the dvd check on the remote control for that function and try to deactivate.Good luck
Aug 23, 2008 | Sanyo DVW-7200 DVD/VCR
Progresie scan
Without a disc in the player, turn it on then hold the play button for 5 seconds. Progressive scan light should go out.
Jan 16, 2008 | Marsh Magnavox MSD124 DVD/CD Player
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Mar 20, 2007 | Samsung DVD-V4600 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
185 people viewed this question
Top Insignia DVD & Blu-Ray Players Experts
Are you an Insignia DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
