Question about Kenmore 57029 Side by Side Refrigerator
The ice maker works, I poored water directly to the ice maker and it works, don't understand what you mean with alligator clips, should i just take the hose leading to ice maker off, the intake water valve must be working because the water dispensor works.
  • 351 Answers
Wrong! ok what it is you have a double water valve. 1 valve goes to the ice maker and one goes to the water dispensor. what you need to do is take the valve that goes to the ice maker by tracing the water line from ice maker to the valve and jump it direct with 110 volts. if you get water by doing that the ice maker is bad if you dont get no water that way it will be the water valve
Posted on Jun 24, 2009
My icemaker on LG refrigerator is making very few ice cubes
If the ice maker is producing ice poorly, making small cubes or too few cubes then it means your ice maker is probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that is not cycling properly.
First, check the water line that's attached to the back of the refrigerator. Make sure it is having a good water flow. If the flow is poor, that means you will have to, repair, clean, or replace the tubing or the shut-off valve that supplies the water in the ice maker.
Second, check the water-inlet valve. You will need to replace the water inlet valve if it has failed.
Third, check the freezer temperature. It should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Lastly, check the ice maker mold thermostat. Make sure that it's cycling properly.
The above is what you need to check on........
I hope this helps....
Take care.
Mar 08, 2011 | Delfield Reach-In 6025X-LG Refrigerator
My icemaker for the LG French Door/Bottom Freezer Model # 25770SW is making very little ice.
Take care.
Mar 08, 2011 | Refrigerators
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Ice maker is afflicted
Hello there. Sorry for your trouble. Your problem is common. I will try to help u. here is some information to get you started:
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Get back and let me know if this helped and what is still a problem.
May 21, 2009 | Refrigerators
Replaced icemaker with new one but still not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Ice line dry on Whirlpool S20b-rsb21
Hi Steve, sounds like you have a indoor ice maker that's cycling but you are not getting any water to fill. Your ice ejector blades should be parked the the 2:00 position. Your beam should flash 2 times with a pause repeatedly. When you hold the left side lever in the light should be on steady. You want to make sure that the inlet tube that feeds the water to the ice maker is not frozen over. You can disconnect the line in the back and blow through it to see if it's clear. Or, you can take a small baster and run hot water up the inlet tube. If that's clear, the ice maker is parked right, but still no water during a cycle then I would look at the valve. If you want you can take a cheater cord and apply 120 volts directly to the valve to see if it will fill the ice maker. Be careful when doing this because you will be working with live juice here. You don't want to light up the world. Best to get a cord and put some alligator clips on it. It it doesn't fill, then there is your problem. Let me know if I can be any more help, Catriver
Jun 25, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
193 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
