Question about Yamaha 12V Air Pump
Hello, i have seem to have forgotton where my ground wire connects to for my 1999 Yamaha GP1200.Please help.......
    Champion:
  • 207 Answers
You can ground it to any clean bolt on the motor make sure its clean and the right size bolt and youll be good
Posted on Jul 08, 2009
Why do three white wires keep melting. also is there suppose to be two grounds from motor to battery.
Hi, Tyler your regulator needs to have a tight clean ground for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/15634-rectifier-regulator-failure-twice.html
melted rectifier wires again
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 28, 2014 | 2000 Yamaha YZF-R6
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
High idle 1997 gp1200
obviously your fuelling isn't set up correctly
Jul 13, 2012 | Yamaha 98 Gp 1200 Air Box Intake Mount...
I have a 02 yamaha yzf r6. Just replaced the neutral switch, and igniton. Something seems to be grounding out. I took the wire harness apart but no wires were bad. What could be the problem?
Hi, Colleen for this scenario you will need a wiring diagram from your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Project Yamaha R6 Part
Yamaha YZF 600 R6 5SL 05
Jun 02, 2012 | 2002 Yamaha YZF-R6
I have a 99 Yamaha FZY R1 and the bike will start but the front dash won't work and I have no headlights and speedometer? The battery was checked and it is fine. Therefore, what do you think the...
Hi, Tom if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/340134-dash-lights-gone.html
R1 1999 speedo problem
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
Aug 13, 2011 | 1999 Yamaha YZF-R1
Headlight does not work
Hi, Rvheusen if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Lighting Star 1100 Wiki Knowledge Base
http://www.starbikeforums.com/forums/49-v-star/8800-headlight-fuse-location-1999-vstar-1100-custom.html
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
May 09, 2010 | 1999 Yamaha V Star 1100 Custom
1998 GP1200 yamaha jet ski won't start
When replacing battery in yamaha GP1200 when attach negative cable the unit seems as wants to turn over the engine while the unit is off and no key in place.. also notice in seconds that the battery terminal on negative side started smoking..actually melt the new battery terminal on negative side..yes, postive was connected to positive. Any ideas what why this would take place??
Jul 15, 2009 | Yamaha 12V Air Pump
Yamaha Road Star 1999 - my two smaller headlights are not working
the wiring is thru the mounting bar and into the lights take the ring and bulb out of the light and you will get to the wires inside but if i had to take a guess it is grounding out inside the tube
Jul 02, 2009 | Yamaha Road Star Motorcycles
Yamaha 12V Air Pump Logo
112 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
