GE JKS05 Electric Single Oven
Problem for GE JKS05 Electric Single Oven
Flashes F7 then stops working
By bonnslove on Jun 24, 2009
flashes F7 then stops working
Solution #1
posted on Jul 22, 2009
Not Rated)
Dutch012
Rank: Apprentice
Rating: 0%, 0 votes
My husband took the control panel apart and cleaned the connections. It is currently working. Good job. Thanks Samurai Fixit.
Was this helpful?
Yes
No
Solution #2
posted on Jun 24, 2009
Not Rated)
jumptrout51
Rank: Guru  GE Ovens & Ranges  Expert
Rating: 90%, 1076 votes
You have a stuck pad on the control board. Push every button several times to try and clear it. If that does not clear the stuck pad you will have to replace the electronic control.
Was this helpful?
Yes
No
Popular Solutions for GE JKS05 Electric Single Oven
Questions and Unsolved Problems for GE JKS05 Electric Single Oven
Do you recommend GE JKS05 Electric Single Oven?
Answer
Answer
SE daño la tarjeta que da el funcionamiento del horno
Answer
JKS05 oven- The fan will not turn on. I suspect the fan switch which should active the fan at 215... (More)
Answer
Light works and indicator light comes on in Broil mode but not bake setting and will not heat up.
Answer
Temp seems to be all over the place....even seems to not heat some times but power is fine and then... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
in , IL
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
