Question about Maytag NMPEB08F2A Air Conditioner
Do you need to add Freon to this product after years of use if so how do you do that?
  • 999 Answers
The freon is a sealed system. If it is low on charge then there is a leak that will need repaired and the correct charge replaced. The equipment and environmental regulations make that a job for the pros. Sorry not a DIY. Reduced capacity is either low charge or failing compressor.
Eric
Posted on Jun 24, 2009
No cold conditioning
Need make and model. Do you know if the compressor is running?
Oct 16, 2013 | Ford Cars & Trucks
1987 dodge ram 50 2.6L 4x4 Where is the a/c fuse? How can I get a/c compressor to com on to add freon? I crossed condenser wires, but compressor does not kick on to load freon. Do you have any helpful...
What refrigerant will you add
R12 has not been avail for over 15 years,
& you need a licence to buy it at $40.00 a can
If you need to add there is a leak to repair
Feb 10, 2013 | Cars & Trucks
I have a 2004 f 150 lariat and my AC doesnt work I turn it on and it shuts off and keeps doing that any ideas
It sounds like you may be low on Freon or have a bad lowpressure switch. The outside temperature can sometimes affect when the A/C will work. If it is near freezing outside, the A/C may not stay on constant, just cycle.
You can switch the lowpressure switch easily without losing Freon. If changing the switch does not help, you need to add Freon. It is best to check for leaks and you really do not know how long the new Freon will take to leak out. Your truck is 6 years old and only needs Freon now. What you add can last another 6 years or 6 minutes depending on the leak.
There are gauges you can borrow from Autozone or Oreillys or a number of independent stores and they are called Manifold gauges. There are also products with leak detectors and stopleak that you add through the Freon fittings. You can do some of the work with the fittings on the new cans and eliminate the gauges, it depends on what you buy.
I would replace the lowpressure switch and see what happens. Then add a can of Freon with stopleak and see how long that lasts you. At some point you will need to determine how much pressure is in the system(how full) and top it off.
Feb 10, 2011 | 2004 Ford F150
How long does the Briskair Duo Thermal ac run before it runs out of freon? I have medical issues and can't breathe over 70 degrees. I can't go out side. Does anyone know where to take the rv for freon? Can...
I would think your RV repairman could add refrigerant. Any heat and air company could do this for you. The unit does not have service valves in it and a port will need to be added. I have seen these units 30 years old and still holding the original charge. It is impossible to say how long it will last. If you need to add refrigerant more than once a year you have a serious leak that needs repaired.
Jun 29, 2010 | Dometic Rooftop RV Air Conditioner
Last couple of years if our thermostat is set below 74 the ac will freeze up. The last 2 years we had it checked out and were told that 1)coils might be going out and 2) needs more freon. Once freon was...
Hello
If your going to have all the freon taken out,this current tech needs to find the leak.
Clearly from what you have said the unit has a freon leak.Freon is put in by ounces or pounds depending on the size of the unit,then you need to get the correct operating pressures.Coils do not go bad they either get full of dirt or get a hole in them.
An 8 yr old unit is a tough call,surley a new one will probably save some electric and come with a warranty.I would get some quotes on a new one,then see how much i could spend.
May 20, 2010 | Fujitsu Heating & Cooling
Massage said low ref ac off what dose that mean thanks
that means low refrigerant available and the low pressure switch is preventing the compressor from damaging itself. You will need freon added to the system which in not uncommon since mobile a/c systems normally leak a small amount each year and eventually need topped off to work properly. Either buy some freon from a parts store or find an independant repair shop that will agree to just add the freon necessay to make the system work again. Freon necessary on most systems ranges from 1 to 2 pounds and freon bought in bulk by all shops costs $3 a pound and labor to do this is about a half hour so look at their labor rate and add a reasonable profit for the freon and this is what it should cost. If this helps please reply cause that helps me and good luck
Apr 29, 2010 | 1998 Cadillac DeVille
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Maytag NMPEB08F2A Air Conditioner Logo
371 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
