Question about OKI Pacemark 3410 Matrix Printer
Can't print continuous feed forms or labels without wasting paper
I can't print multiple (50 or 100) copies of the same label or form because the printer skips at least 1 page and starts printing in the middle of the next page. I waste 2 pages for every good page I print. I have tried every option in the user's manual (which sucks, by the way).
Any help would be greatly appreciated.
  • paula_sisson Jul 28, 2009
    No, I haven't gotten any solutions to the problem. It seems that many people have this problem. I have called OKI support and they couldn't resolve it either.
Did you get this done.? I have the same problem, Lafayette,Indiana Realtor
Posted on Jul 28, 2009
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
The printer adds an extra line space at the end of every label I print, by the 4th label they aren't usable
You could fix this in the printer, but faster and easier to alter your program's printing function. Check that you are using the correct form template, and either delete one line from your data, The program may be issuing a line feed, or modify the form dimentions.
print on blank paper until you get it dialed in. Hold up to light and lay labels over or under it to see alignment
Oct 15, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
Balster advantage label printer form feed
Hello David,
You have to make sure that the printer is not running out of ink.
Try to uninstall/re-install the printer driver. This often resolves the issue about printing problem.
Apr 16, 2009 | ATSI Holdings BD422003 Thermal Label...
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Nov 20, 2008 | Zebra QL420 Thermal Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
OKI Pacemark 3410 Matrix Printer Logo
393 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
