Question about Lasko 5540 Ceramic Compact Heater
Poping, smoking electric Lasko 5540 heater
When heater is turned on, after a few seconds, it starts poping and smoking (as in an electric short)
  • 242 Answers
It depends on where the smoke is coming from. If it's from the heating elements, it's normal as dust and residue burn off. If it is coming from the control section, it's bad and the heater should not be used.
Posted on Nov 21, 2008
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
Fan only runs briefly after short rest repeats short run
Your proplem could be caused by poor air flow. Make sure all the screens on the unit are clean and free of obstrutions. Also you leave at least 4inches of free space all around the unit.
Sep 05, 2010 | Lasko 5540 Ceramic Compact Heater
Poping sound, sparks shooting out and 220 circuit breaker out
Did you move the breaker fully off before turning it back on? make sure the offending burner is off.
It sounds as though the element shorted out.
Mar 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Compressor is not running, poping sound when electricity supplied
The popping sound could be a direct short circuit, in which case you need to try to see where exactly the sound is coming from. You should then be able to correct it. Second thing is that it is possibly a bad starter relay and can easily be replaced. ratemeplease
Mar 12, 2009 | Samsung 25.5 Cu. Ft. Side-by-Side...
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
You have too many things on the circuit you are on. Either move it to a different plug, or turn some things off. A plug in heater uses as much electricity as the breaker should carry if it is a 15 amp, like most are. Try to find a plug on a different circuit, or clear some things off of it.
Dec 22, 2008 | Lasko 5540 Ceramic Compact Heater
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Absolutely no power to my Lasko 5540 heater
There is a thermal fuse in line with the power chord. Open your heater housing up and trace the power cord. It is located inside a white teflon sleeve. Locate the fuse and either replace it with the same value. Appliance repair shops will have them in stock. If you want heat right away, cut out the fuse and jumper the 2 wires together. Instant heat.
Nov 21, 2008 | Lasko 5540 Ceramic Compact Heater
No power
Go to the Lasko Website and get a new one for free. They were recalled
Jan 17, 2008 | Lasko 5540 Ceramic Compact Heater
Popping, smoking electric Lasko 5540 heater
Connector for power cord overheats and shorts. Bottom safety screw can be undone using the bacj end of a jig saw blade.
Replace wire connectors with different wire connectors - wire nuts etc.
Nov 05, 2007 | Lasko 5540 Ceramic Compact Heater
Lasko 5540 Ceramic Compact Heater Logo
166 people viewed this question
Top Lasko Heating & Cooling Experts
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
