Question about Whirlpool Duet GHW9150P Front Load Washer
It beeps and flashes hf - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
The "FH" fault code is a No Water Detect error. The following link explains how to troubleshoot:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Begin by checking all the easy things you eliminate first. Such as making sure your water taps are on and the fill hoses are not kinked or clogged. You should also inspect the sediment screens on the back of the washer where the fill hoses connect to make sure they are not clogged.
Then, I would recommend you check your drain hose placement to ensure you don't have a siphoning problem, followed by an inpsection of the drain pump reservoir to ensure it is not clogged, and verify that the pump runs.
Read through the link provided and look at some of the follow up comments/tips from other users. Some of this add-on advice can be partcularly helpful. Let me know if you have any questions. I hope this helps you.
Posted on Jun 24, 2009
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Install. ImageMix. (Canon HF-10), not accepting the serial number
I found another serial number under the batteri, and then it worked out fine.
Jul 30, 2009 | Canon FS100 Flash Media Camcorder
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
globul1a.gif If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door was leaking and now it shows error code H F
hf means no water entering unit,,,make sure that there not water in unit already..make sure your pump is not clogged,,if need be post question how to clean pump or just contact me,,also make sure theres no kinked inlet hose,,and or drain hoses..check and see if your inlet screens are clogged..onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
122 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
