Question about Sanyo VHR-H531 VCR
Buttons for TV control on remote don't work
When I pressed the buttons for TV control on remote control, nothing happened, I don't have a book for its programming.
0 characters
1 Points
Which button do I push to remove a disc from the DVD Player with my Universal GE Remote? My JVC TV/DVD Combo has no buttons and the Disc is in it. I have lost my original Remote.
in the time it took to write this you could've pressed each button to find out,if none work,then you need to program a different number for the dvd player,not all codes operate every player
Jul 11, 2015 | GE 24927 Universal Remote Control
Vcr recocognizing my remote.
Hi coldrh what remote controler aer you using?
Jan 03, 2008 | Philips VRZ362AT VHS VCR
Sony RM-Y186 remote will not work what is wrong with it?
1. don't press the buttons like a hardcore boxer :)
2. disassemble the remote control. No big deal. It has a plastic housing the buttons are on a plastic/rubber sheet. (remove batteries first)
3. clean the plastic/rubber sheet where the buttons are both on top and rear side. Take some clean petrol from the groceries next corner, and clean the black pads on the bottom of the buttons + also on the circuit sheet you'll find inside the remote control.
4. Put everything together and...
... TADAAA! It works again. :-)
Jul 20, 2014 | Sony Wega Tv Remote Control Rm-y180 4...
Will a Phillips Universal operate a Samsung DVD-2000, and what ar
YES! if you have a universal remote look in its manual and program the code for your samsung into it. there are some buttons like SET and TV1 2 etc Select TV1 and SET buttons a red LED comes on, enter the code (eg: 013) the red LED goes out Press set aain and then press power on remote TV shoulod turn off if it doesn;t try anothyer code until you have control of the TV
Aug 11, 2009 | Samsung VCRs
Cannot get channels with remote stuck on AV2/3/4/5/6
The TV button on the remote is to select TV mode for the controller. STB, VCR & DVD do the same for their respective devices.
The A/V should select the external inputs by itself. If not try each of the Panasonic codes in turn:
0011, 0021, 0027,0029,0039,0072, 0102
Enter the codes as follows:
Press and hold TV for 3 seconds until the TV key flashes and then stays on.
Enter one of the codes (above)
TV key should flash twice. (if not go back to the beginning)
Try pressing the buttons on the controller. If all the functions do not work, try the next code.
Aug 03, 2009 | Rio Go Video DDV9475 Dual Deck VCR
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
Goldstar 2,9
Hitachi 8
Magnavox 4
NEC 2,9
Pioneer 6
Philips 4
Sanyo 0
Sharp 3,5
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi VCRs
Remote codes
Hope this helps.
Feb 27, 2009 | VCRs
Aiwa GX1100 VCR
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
Sep 13, 2008 | Aiwa VCRs
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | VCRs
Lost manual to program remote for Toshiba M-68C VCR
-Push "TV" and release.
-hold prog and enter the two digit code. (Try 10 for a phillips) release the prog button and see if it worked.
If not try experimenting with other two digit codes as I don't think there is an auto search for this remote. At worst it'll take 99 attemts to work ;-)
Feb 03, 2008 | Philips VR330 VHS VCR
VCRs Logo
24 people viewed this question
Top Sanyo VCRs Experts
Michael Houda
Level 1 Expert
Are you a Sanyo VCR Expert? Answer questions, earn points and help others
