No power led illumination to simpletech 250gb hard drive. are the power pcbs avail for for purchase p/n on pcb HDD-2518-SATA V1.0. OR DO YOU KNOW COMMON COMPONENT FOR FAILURE ON PCB?
  • Randy Jun 25, 2009
    i did put both usb's still no luck
  • 334 Answers
Just want to check first, are you supplying enough power to it? They use a lot and sometimes require to be plugged into 2 USB ports, let me know
seth
Posted on Jun 24, 2009
  • seth veloso Jun 24, 2009
    Wow, I am actually unable to locate the part you need anywhere. It is likely that it failed due to excess heat though. There is a link below to support for simpletech, they may be able to help or the part might not be sold. You could always buy a new one and swap out the board to recover if need be.
    Good Luck
    seth
  • seth veloso Jun 25, 2009
    wow, sorry man. If you were not using 2, this may have caused the failure, overheating due to low power. The only other thing I can give you is the website to contact support and see if they will give you one but I doubt it. Worth a shot though. Good luck
    Seth
    http://www.simpletech.com/webspeed/webte...
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
Jumper settings fujitsu mhz2250 hdd
At the back edge of the hard drive next to the data and power connectors the is a jumper position for configuring the hard drive. Look at the circuit board and the jumper position will be marked as follows. SL = slave
CS - cable select, put the jumper into one of these position of your choice.
Apr 17, 2012 | Fujitsu 2.5 Hdd 250gb 5400rpm Sata...
Boot device
your hard disk has upto 3 years warranty from the day of purchase
May 26, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
The power adapter does not work
open plastic case and pull out the sata hdd and put it in a comp with sata support
Jul 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
PS3 hard drive transfer
seagate eSATA 250gb hard drive, the PS3 uses a laptop sata drive, how you get this to work?
You have basically have 2 options you could try:
Use Linux for retrieve the data of get the original mainboard back.
The PS3 + HDD bonds together, so if you were to save stuff eg, online purchases, you need to have the same account for max of 5 downloads to 5 differenct units, BUT you cannot just swap out the HDD and expect it to work. The PS3 has a feature to backup from internal directly to an external USB hard drive but online limited to data, most purchased movies and/or MP3 will not be transferred, it sucks.
You can have as much HDD you want but only YOU can use them , cannot be shared with another PS3. I hope that helps a bit
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My computer wont read my Simpletech 500gb hardrive
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 gb external hard drive
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SumsungHDD Fails to load OS
Try:
Have you got a decent spinup?
Are the rest of the drives working properly, if they are not it may suggest faulty PSU.
Try connecting to a diffrent pc, or purchase a USB sata convertor
Aug 13, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
350 people viewed this question
David Payne
David Payne
