Question about Zebra Eltron LP 2824 Thermal Printer
We are trying to print a file using TL Ashford to our printer but it prints out the actual code and not the label. is the printer in the wrong mode? If so, how do you change the mode?
SOURCE: Printing Speed
what interface are you using? sounds like windows is sending the data to the printer as graphics which is much more intence then EPL hence the delay between each label.
Posted on Nov 21, 2007
  • 38 Answers
SOURCE: Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Posted on Mar 05, 2008
  • 17 Answers
SOURCE: Read and print .DAT files on labels
you must embed ZPL/CPCL or EPL command to your program.. or use Zebra Designer Pro then connect the .DAT file to it and design your sticker..
Posted on Mar 21, 2009
jwr1914
  • 31 Answers
SOURCE: Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Posted on May 27, 2009
SOURCE: TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Posted on Aug 17, 2009
Our thermal label printer Zebra 2844 prints labels upside down. I have tried "rotate 180 degree" in printing references and printing default and also tried to use "Always use driver...
That means that your settings are wrong or the commands are not transmitted.
You are probably in inline mode try to switch to page mode
Aug 15, 2011 | Zebra LP 2844 Thermal Printer
Hi, i have a TLP 2844 printer Thermal, but i cant print labels. I have read the manual and follow the instructions. Every time i put labels on the printer, only send me blanks. Can you help me, please
Are you trying to print in thermal or thermal transfer mode? If thermal transfer mode, do you have the ribbon install correctly with the coated side facing towards the label? If using thermal mode, are you using thermal paper and are you trying to print on the coated side? Hold the feed button down and turn the printer on. Hold it down until the light stops flashing. At this point the printer will print a diagnostic dump. If nothing prints then either you have the media loaded wrong or something else is wrong with the printer.
Jul 19, 2011 | Zebra LP 2844 Thermal Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Small label is being cropped at the top
Have you tried the menu settings for start top of label? If other printers work, you are talking about a configuration setting. I would get a configuration off another printer that works and look at yours real close.
May 01, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
ZEBRA PRINTER
Try reloading the TL LATCHFORD software
Thank You
Mar 10, 2008 | Office Equipment & Supplies
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
107 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
