Replacing a motor coupling
I just received a reply to my orginal question. The answer was that I need to replace my motor coupling. Can you direct me to how I can do this? Is this something I can replace myself? Is this part expensive? Thank you, Corina
  • 5,911 Answers
I'm assuming this is a Whirlpool or Kenmore model top loader washer (?). If so, replacing a motor coupling is not a terribly difficult process and its not expensive. The motor coupling itself only costs about $15-$20. The labor, however, would eat you up if you decided to have someone put in on for you. However, if you feel this is beyond your capabilites, don't hesitate to seek the proper assistance you need. If I'm correct in my assumption on brand name, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when it is released.). Once the top clip is released, the bottom one should come out fairly easy. The clips are similiar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with with a rubber bushing connecting the two. Once plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Make sure you replace BOTH halves of the coupling even if one side appears good.
10. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
11. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in it's keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top brakcet keyed into its slot and snapped back into place.
12. Reinstall electrical connector to the Drive Motor.
13. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
14. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
15. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, then forcefully push it into the opening on top of the washer. It will snap back into to place.
16. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
17. Reinstall console.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. If you have any further questions, please post back with comments. I hope this helps you.
PS If you need a part number, post back with your model number and I will get it for you. The part is carried by almost any appliance repair store.
Posted on Nov 05, 2007
I just wanted to say thank you. I was able to fix the problem. Thanks so much for you advice and help. I purchased the motor coupling and replaced the old one. This did the trick. The whole job only took about 30 minutes. Thank you, Corina
Posted on Nov 06, 2007
How do I replace the motor coupling
Washer Motor Coupling (part #285753A) - How To Replace ...
? 8:35
Aug 4, 2011 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace the drivemotor coupling on top load direct drive ...
Motor coupler replacing Whirlpool direct drive washer ...
? 5:08
May 22, 2011 - Uploaded by theapplianceman
For more videos visit my website at
Nov 23, 2015 | Washing Machines
Replying to a response to my first/orginal query - illegal characters
Hello, Alex -
Those who answer questions on are volunteers. Plus, if your question wasn't accepted because the question algorithm did not accept some text / characters in your question, that question did not get posted and no one volunteering to answer on Fixya even knows what you wrote.
I suggest you contact Customer Support:
Jan 09, 2018 | Televison & Video
I would like to know how to put on a Technics SL-J110 Belt Drive back on please.
For most of the belt drive turntable the procedure is more les the same:
Pull up the rubber mat, pull up the platterand find the belt. If the belt is removed from the platter, replace it with theglossy side outward. Pull the platter back at the original position. Turn untilone of the 2 big openings come over the motor pulley. With your finger placethe belt from the platter at the motor pulley. Pull the rubber mat back. Youare ready. Here is a schematic for all the above:technical114_86.jpg
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 04, 2011 | Audio Players & Recorders
How do you remove turntable to get access to belt drive?
Depending on the brand / model the procedure may be different. For most of the belt drives pull up the rubber mat, pull up the platter and find the belt. If the belt is removed from the platter, replace it with the glossy side outward. Pull the platter back at the original position. Turn until one of the 2 big openings come over the motor pulley. With your finger place the belt from the platter at the motor pulley. Pull the rubber mat back. You are ready. Here is a schematic for all the above:
Thanks and regards
direct fixya link:
Jun 20, 2011 | Audio Players & Recorders
Last week I requested information about how to open this dryer in order to replace the heater element. I paid a total of $16.00 for the answer. I have not received it yet. Is this rhe way it is or I am...
I'm not sure what happened in the event you did not receive your answer, but I know I personally posted a reply to your requested and provided a fairly complete solution.
Check the link I've attached here should direct you right to the post I'm referring to. If you do not receive it, please reply immediately so I can follow up and report a problem.
Sorry for your troubles, hope this works for you. Good luck.
Macmarkus :)
Mar 02, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The wipers and washer won't work...replaced the motor, still nothing...the motor does work but cant get it to work through normal operation. I had to jump the motor directly to get it to work.
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 16, 2011 | 1998 Honda Civic
Our washing machine is spinning but not agitating. Do I have a problem with the motor coupling?
Yes it can be motor coupling problem or motor related problem.Both the motor coupling and motor itself needs to be checked. Motor coupler it's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. But if both the motor coupling and motor checks out ok then the transmission and agitator assembly itself needs to be checked. You can get required parts from
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Washing Machines
How do you seperate the motor from the agitator to replace the agitator bushing?
Hi, If you mean how do you replace a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
a8ee26c.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Jan 05, 2010 | Kenmore 24902 Top Load Washer
Whirlpool direct drive washer wont spin
Well I ended up having to trouble shooting the problem on another web page that didn't cost any thing to get my answer.  I sent my first entry in and received a reply.  I then sent in a second entry because through trouble shooting my washer I figured out that it was not a motor problem but never received another answer.  The problem ended up being the drive clutch.  It was worn down and was which caused very little friction and the clutch never caught to spin the basket.  Now it spins great.  Seeing as how you did not provide the help you said you would it would be nice to get a refund.
Thanks Rich
Apr 18, 2009 | Whirlpool Washing Machines
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
