Question about Samsung YP-K5 MP3 Player
My yp-k5 is not working.........the screen buttons itself is disabled..wen switched on.....i get a message.to delete 20 mb files......how can i do that wen d buttons itself r not working.....i tried formating the device in my pc..........that also failed.....wat sud i do .plsssss reply
  • srepss Jun 25, 2009
    teri maaa ki chooth samsug....teri maaa ki jaaath choud bosudike
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
First off, make sure the unit is not on hold. You can check that by looking at the side for the HOLD switch.
Next try to reset the player. Here's how you do it:
With the unit, get a paperclip and poke the reset hole at the back of the unit until the unit shuts off.
Try to turn on the unit and check if the buttons will be activated. If they'll work, format the player.
Next, what exactly happens when you try formatting the player using your PC?
You can try going to My Computer. There, you're going to see teh YP-K5. You DO NOT format that. Rather, double click on it. You're suppsoed to see a STORAGE folder. Right click on that directory and select FORMAT.
Hope this helps!
xo
R
Posted on Jun 25, 2009
  • AmyMona Dec 08, 2010
    I got similar problem. while i was listening the musics, the machine automatically switched off. Then i cannot turn on. Even when using USB connector for charging with my laptop, machine did not function nor charging or active at all.
    So the first solution i tried and solved my problem, just by using paper click press it to the RESET button. And machine start working agian :)
    Thanks !!
I have problems with my Samsung YP-T7JX/XAA 512 MB When I reset it appears loading and after the follow message NO space for DB Please delete more than 4.0 MB After this just a SAMSUNG screen...
mp3 player screen says, None and No File, after I formatted it using Windows Media Player. Now I can not transfer or synchronize.
Do you know how to fix it?
Please Help.
Feb 01, 2011 | Samsung Yepp YP-T7JZ MP3 Player
Problem with YP-K5 QB
there is a bug in the software...try o contact the manufacturer and service it or replace it if its under the warranty period
Sep 23, 2008 | Samsung YP-K5 MP3 Player
YPK5 Stops
connect it to the computer and charge 4 round bout 30 min n take it out and hold on wen it comes up it should work again dats wat i did wen dat happened
Aug 31, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-K5 won't work
Get the latest firmware upgrade from Samsung website, or call 1-800-SAMSUNG
Jul 06, 2008 | Samsung YP-K5JAB MP3 Player
Can't delete or copy files ?
yp-t7 is builded w protected switch,to prevent loss data,
u can switch that by click reset button when u is connecting on usb port
Apr 25, 2008 | Samsung YP-T7Z MP3 Player
Samsung yp-u3j ZB/XEU freezing/computer not recongising after i deleted files from the device
Hi...I find the answer...Push and hold rec button and button for holding...And it will start..
Jan 26, 2008 | Samsung YP-U3JQB MP3 Player
Broke
before i had the same problem, when i thought my k5 runs out of battery i plug it in to charge, but it said charge complete and when i unplug it, it still wont turn on. but then i tried switching to a different usb plug on my computer and it worked. so i guess the problem is that some of your usb slot on your computer isnt working properly, try using a different slot.
Jan 20, 2008 | Samsung YP-K5 MP3 Player
Rtc error samsung yp-k5
I had the same problem. Won't turn on but when connected to laptop via USB it shows RTC (real time clock?) error, then syncs, then shows image of battery and says FULLY CHARGED. I downloaded the firmware and installed and all that did was delete ALL the music on the device and it still doesn't work. It is just out of warranty. Does anyone know a company that fixes these players?
Jan 17, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-K5 MP3 Player Logo
265 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
