Question about Kenmore 98702 Stacked Washer/Dryer
How do you get the front cover off the dryer?
Help! Our stackable washer/dryer has a bad noise in the dryer. I'd like to check the rollers, but can't figure out how to get the front cover off after removing all the visible screws. Any help would be greatly appreciated!
I have had the same problem and it turned out to be because the fan cage slipped of tge motor shaft
Posted on Nov 15, 2007
  • 146 Answers
Try removing the back cover to gain access to the dryer motor and other bits. Feel around the drum and around the lip of the drum at the door opening. There could be a wire or chain stuck between the drum and the frame.
Posted on Nov 05, 2007
Frigidaire stackable washer making loud clunking noise when spinning
You will need to take the front cover off and check to see if there is anything lodged between the drum and housing.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
Have a 2780 dryer stackable that is leaving grease/burn streaks on my clothes. it seems that lower front of drum is not sitting flush. there is a gap against the wall where clothes or dryer sheets get...
you need replace drum support roller,an check to make sure drum hadnt cut into back are the front of dryer the felt that drum roll around on may allso need be replace.some ge dryer have single bear it roll around on it attack to back of the dryer drum
Feb 28, 2018 | GE WSM2780DWW Unitized Spacemaker Washer...
Our dryer is making terrible squeaking and bonking noises. The bonking came first. We want to look inside and see if we can fix it. How do you open the front or do you access from the back? Its the...
It sounds like the drive belt has SLIPPED out of the indented area (trough) of the indentation or it is loose, beginning to crack etc. OR one of the guide rollers has broken or gotten loose. Open it from the FRONT, taking off the metal cover. You will see the drum and the belt. Turn the drum by hand and inspect the belt, make sure it is in the metal trough, tight has no frayed, cracks in it. Check the guide rollers and the springs too.
Feb 06, 2018 | Frigidaire GLEH1642DS Front Load Stacked...
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Drum shakes
check to see if you removed the shipping braces refer to your owners manuel
May 25, 2008 | Kenmore 43142 Front Load Washer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
101 people viewed this question
Sal De
 Brian Main
Brian Main
