Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Tractor won't start fuel is fine and I put in a new fuse. It won't turnover at all.
  • 999 Answers
Loose or corroded connection on the battery cables or safety switch not working. I had a similar problem and had reconnected a wire and missed the spade. Could be a bad start switch. This will require tracing the power till the break is found.
Eric
Posted on Jun 24, 2009
Won't start when facing uphill or flat only when facing downhill.
sounds like a fuel pump fault, gravity is the only thing feeding the engine, then when engine is running the suction is sucking fuel in.
Jun 05, 2017 | 2003 Chrysler PT Cruiser
Engine won't turnover
It sound like the starter solenoid that forces the starter gear onto the flywheel, you need to replace the solenoid unit.
Mar 30, 2013 | Rear Right Window Regulator & Motor for...
My Husqvarna YTH2348 tractor won't start. Nothing
It could be a couple of different things. A couple of things that you can check yourself before having to take it to someone to look at it:
1. Open the hood and try turning the engine by spinning the round "cheese grater" looking part that is attached to the flywheel. - it probably won't turn.
2. Remove the spark plug(s) and try again. (Be careful, if the the cylinder is full of gas/oil it will come out as you spin it by hand.) - DO NOT use the electric start to try and turn it over! This sends spark to the plug wire and could ignite any fuel causing severe burns and/or other serious injuries.
-IF-
You were unable to spin the engine over by hand without the spark plug(s) in it, then you may be dealing with anything from a wedged starter gear to a seized engine. Fuel with ethanol added to it attacks the rubber/neoprene seals in carburetors and often times allows fuel to fill the crankcase and cylinder. If this has happened the above mentioned plan of action will let you know. As always, anytime the fuel mixes with the engine oil, you should change the oil to prevent the engine from locking up under normal operation.
I hope this gives you a little bit direction. =)
Dec 23, 2011 | Husqvarna Garden
John Deere 4400 tractor won't start
Pull spark plug. If you fuel that why.
Nov 19, 2011 | Garden
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My cadillac escalade esv 2003 ran out of gas when I put gas back in It now it won't start or even turnover
my cadillac escalade esv 2003 ran out of gas when I put gas back in It now it won't start or even turnover
May 24, 2010 | 2003 Cadillac Escalade Esv
Will not start, does turnover, but seems to be getting no gas. will turn over if i spray auto start in the carborator.
check fuel filter to see if its clogged. (cheapest easiest)
if that doesnt work rebuild carburetor (expensive but fairly simple)
if that doesnt work pull tank if it is low on gas or pull bed if gas tank is full a replace fuel pump (time consuming, hard to do, but fairly inexpensive) I had this problem on a silverado I had and it was the fuel pump.
Sep 30, 2009 | 1991 Chevrolet C1500
Cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Jul 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman lawn tractor will not start/turnover
Are you sure the safty switch is working. It sounds like its in the seat switch or the pedal switch.
You can sometimes jump these switches over with a paper clip or small metal wire to make contact on each side of the plugin.
this being on the machine side.
Also PTO cluth may be seized. in the on position locking up the motor. and blades.
Jan 30, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
