Question about Pioneer DVR-220 DVD Recorder
DVR-220-S Capacitor C19
Recorder will not power on. I opened the cover, the fuse is ok. the capacitor
#C19 seems to have burst, there is a brown spot on the top cover over this
capacitor. Would this cause the recorder not to power on? if so do you know where I can get the capacitor? I haven't unscrewed the circuit
board but am assuming it must be soldered into place, would this be
correct? If so what type of solder would I use? If you can help it will
certainly be appreciated since there are no repair services available within
100 miles. Also, I could probably buy anew one for less the cost of repair.
Thank you
  • 5 more comments
  • Joe Coyne
    Joe Coyne Jan 02, 2008
    I have a Pioneer DVR-220-S C17, C19 and C23 all have the end blown out and will not power up. Looking for shematic.
  • clower2003 Feb 13, 2008
    my pioneer also wont power up c23 c17 c19 c24 all look to be blown (swelled and leak) went to www.mouser.com they sell capacitors think i payed 8 to 12 dollars for 2 of each. c17 is on back order still waiting for it. does anyone have the schematic they could email me. paying for a schematic is ridiculous. or a bit-torrent page where i can find it. will let you know if this solves my problem have to wait 4-08 there suppose to receive the 25v 1800uf.
  • juanian Jun 09, 2008
    Yes, I too have the same problem. c17, c19 is bulging, and c23 has brownish gunk on top. My c24 looks ok though.
    I found the location on the Poineer site where they sold the service manual - $27. I didn't see the power supply board for sale there.
    I'll try and get the capacitors at Fry's tomorrow and see if replacing them fixes the problem.
    I have another DVR-220-S, but I haven't opened it up yet (and it hasn't had a power problem -- yet).
  • 98z3 Feb 01, 2009
    Same problem here -- C17, C19 & C23 are damaged with electrolyte pushing out the top. C24 looks okay but I'm going to replace it while I'm at it. I am ordering capacitors from Digi-Key.
    I am posting the capacitor specifications here to help the poster that said his caps were too destroyed to read.
    C17: 1800uF, 25V
    C19: 3300uF, 10V
    C23: 1000uF, 10V
    C24: 200uF, 10V
    It looks like the set of 4 caps will be about $5 or $6 including First Class USPS shipping.
  • eutex Feb 02, 2009
    After 4 years of use - same problem. The recorder won't power up. The fuse was fine. I did find the brown spot with ant mount-like brownish powder on C23 (1000 uF, 10V), as well as noticed that C19 (3300 uF, 10V) has a bulky top. Upon connection I had an impression that both capacitors are warmer than all others. It could only mean that they leak current causing DC voltage to drop and not power the circuits. I went to www.mouser.com and ordered the two capacitors. Couldn't think of anything else. Hopefully it will fix the problem. Not sure what's causing this problem...poor quality capacitors, or poorly designed circuit.
  • 98z3 Feb 05, 2009
    Here's an update: I replaced C17, C19, C23 and C24. Now the DVR-220 powers up and plays fine.
  • Mike_2032 Apr 01, 2009
    Same problem ,wouldn't power up. I found this site and started reading. Reopened my unit and saw the brownish dust over c23, c17 and c19 are swelled.
    Finding this site has been a real help, I wasn't looking forward to going and finding another recorder that allowed for the 10min intervals.
    Thanks Guys
  • 4 Answers
I just purchased the following capacitors from Mouser.com. I bought 2 of each and with shipping it cost me about $10:
C17: 1800uF, 25V, D 15mm L 20mm - 647-UPW1E182MHD6
C19: 3300uF, 10V, D 12mm L 25mm - 647-UHM1A332MHD
C23: 1000uF, 10V, D 10mm L 17mm - 647-UPW1A102MPD
I could not find a replacement for the C24. My C19 blew and after replacing it the DVR came back to life.
Posted on Mar 08, 2010
I replaced the c17, c19, and c23 caps, and my DVR-220-s is now powering up properly.  I used Nichicon PW caps to replace the old Elna RJF caps, and the new caps were a perfect fit.  (Cost of 2 sets of caps was under $5 at DigiKey.com with USPS Priority Mail shipping also under $5.)
I did notice that the area around d39 was a darker brown.  Time will tell if any 'permanent' damage occurred.  (Once I extracate my other 220, I'll replace those caps also.)
One other note: My 30w soldering iron was underpowered for the job, but a 45w worked OK.
Posted on Jun 16, 2008
  • Richard Wein
    Richard Wein Jan 18, 2014
    I replaced c19 & c23. Now it powers up but goes into standby in 5 seconds. Should I replace c17 as well? Or what can be the problem now?
You can download the Service Manual for this machine for $10.00 from the following site. www.electronicsrepair.net
It includes the schematic for the power supply board.
You can also buy the complete power supply board on line for about $52.00 from www.partstore.com.
Posted on Jan 03, 2008
This is exactly what appeared to be the problem - capacitors fail. Out of 4 mentioned by another person, I discovered that only 2 failed - C19, 3300 uF 10 V, and C23, 1000 uF 10V.
You can buy them at www.mouser.com. I bought Nichicon Low Impedance Radial Aluminum Electrolytic Capacitors:
P/N 647-UPW1A102MPD and P/N 647-UHD1A332MHD
Very inexpensive but you will have to pay about $5 for shipping.
30W pensil solder worked fine for me. You can buy it at Radioshack, they will tell you what else you may need to do a quality job.
Now it powers up without a problem and work just fine.
Posted on Feb 05, 2009
An update on my experience: I replaced the four capacitors (C17, C19, C23 and C24) and now my DVR-220 powers up and plays fine. The parts were $4.83 including shipping from DigiKey.
I have a DVR-220 with the exact same problem but most of the caps are so bad I can not read their size. Would someone please post the cap size (voltage and mfd) along with part number (C19)?
Any help is appreciated
Posted on Nov 17, 2008
Thank you for the reply. We went to the Pioneer Website
and downloaded the service manual/schematics. We called
them and they said they did not sell the capacitors individually,
we ordered the whole power supply board for about the same
price as quoted in your response. It only took a couple of
days for it to arrive. It is now working.
DVD player powers on and then returns to standby mode
hi richard.
i have had a look around the internet but all i could find was the is link.but when you go to it its forums that you can go into.so not to sure if it will be off any use,but have a look.
Pioneer DVR 220 DVD Recorder powers on and then returns to standby mode...
Nov 07, 2017 | Pioneer DVR-220 DVD Recorder
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
I can not get my recorder to work when I plug it in it dose not come on. I lost power a couple of times when I was at work now it will not come on. where can I get it fixed
Check the in line fuse...If you remove the unit cover the inline fuse sits right behind the plug socket...If the fuse is okay, then you will need to replace these two capacitors on the same power circuit board...One is at location C19, 3300uf, 10 volt, and c23, 1000uf, 10volt...
Aug 08, 2010 | Pioneer DVR-220 DVD Recorder
I own a Pioneer DVR-220 dvd recorder and my problem is that the unit will not power up. I've tried disconnecting the ac power cord from the Monster Power power source and connecting the power cord via an...
I replaced two capacitors, (1) 10 volt, 1000uf and 10 volt 3300uf..They both sit on the power board that can be removed from the unit..You will have to unsolder the bad capacitors and put in the replacements..This wasn't hard to do...
Jun 26, 2010 | Pioneer DVR-220 DVD Recorder
Pioneer DVR-220 will not power up. Any suggestions.
First check the in line fuse...it sits right behind the electric plug on the chase..You have to remove the screws to open the case to check this....If the fuse is okay, you will have to replace these two capacitors, 10 volt, 3300uf, and 10 volt 1000uf...they are located on the same board that houses the fuse...the two location are c23 and c19 on the power board...
Jul 08, 2010 | Pioneer DVR-220 DVD Recorder
Startup goes to Hello menu and freezes. Clock starts then goes to hello once eject or any other button is pushed
Unplug the unit, open top cover, look closely at every power supply capacitor and see , if any of them has been popped open. Replace all popped capacitors with the new once.
Nov 25, 2009 | Cyberhome DVR 1600 DVD Recorder
No power at all on my magnavox mwr10D6
Brown outs can damage the power control board of a running product. It's likely that while the other devices that all were affected by the brown out made it through such a condition, your DVR probably did not. The good news is, there is typically a fuse that can be changed which may have blown. If you open the unit up, check the fuse first. If it looks okay, there is a set of capacitors (looks like tiny round cans, usually blue or black) If there is what looks like a weird papery appearance around the can(s), or the top of the cans are bulged or cracked, the capacitor(s) need to be replaced.
Nov 28, 2017 | Philips Magnavox MWR10D6 DVD Recorder
Cyberhome dvr1200 wont turn on
dave727,
C14 & C20 are in fact 2200uf @ 10VDC. C15 is 1000uf @ 10VDC. After reading these posts, I took a closer look at the ps board, and sure enough C20 top is slightly ballooned out. We'll be replacing all 3 with 16VDC caps shortly. BTW, the high pitched whine is from the power supply because it's a switching supply and creates some HV.
Thanks for the input!
dondd
Jan 13, 2008 | Cyberhome DVR 1600 DVD Recorder
Power Supply Burnout
Apparently there was a problem with some of the capacitors in these models. Your capacitor definitely is popped.
I had the same problem. The fuse was okay, but two capacitors were blown. One was at location C23 and I think the other at C17. I took it to a local electronics shop and they replaced and soldered the new capacitors on for me. It only cost $16.22. They were a 3300 µF and a 1000 µF.
Check out this information on this site as well.
http://forum.videohelp.com/topic340925.html
Dec 28, 2007 | Pioneer DVR-225 DVD Recorder
No power on magnavox dvd recorder model CMWR10d6
The capacitor blew. You need to get that replaced. That little capacitor stores that electrice charge to power your unit on and timer programmings etc. Either get that fixed by yourself or call support line.
Dec 27, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
2,325 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
