Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Toro Rake and Vac blower/vacuum 51573 and 51591 will not turn on.
Took apart and directly checked motor - works fine. Continuity checks on other wires are good. Diode does not show continuity thru it with or w/o switch on? If I check it with amp meter what should the reading be? Should this be done with the unit plugged in? Is it better to just replace the entire switch element or just the diode if it is bad? Thanks for your help.
fly_at_home@hotmail.com
SOURCE: Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
Posted on Nov 25, 2008
  • 548 Answers
SOURCE: Snow blower spark plug replacement
I would check it at the start of every season and clean it. If you note that it seems to be running rich and might have fouled the plug, you can always pull it and check it again. Probably not a bad idea to check it before you put it away for the season. As for replacement, it depends on condition. I would think that you should get two or three season's use out of it before needing to replace it, at least.
Posted on Jan 25, 2009
  • 4 Answers
SOURCE: My Toro Super Blower works fine & then I notice smoke at the cord
sounds like your blower is drawing to many amp`s for the cords your using for this
Posted on Feb 13, 2009
  • 66 Answers
SOURCE: Toro Super Blower Vac will turn come on. Is there a reset button?
Yes there is. Unplug the unit, pull the plastic adapter that converts it between vac and blower off and you'll see the little square reset button. It is recessed into the case. Push it in until it clicks, replace the adapter and plug it in and go. Good luck!
Posted on Jun 19, 2009
rwvanlue
  • 486 Answers
SOURCE: Have rake and vac - lost manual - cant figure out
Here is a link to a copy of the manual
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 11, 2009
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 03, 2014 | Toro Garden
I have an Oreck Xl upright vacuum. when i plug it in the light on the switch is on but the vacuum wont start. i took it apart to check the wiring and seems fine. is this a switch or motor or? problem. ...
I assume that you have a two speed switch and neither speed works. If you have access to a multi-meter I would check continuity through your cord going to the motor and the switch and also the motor itself. Anything where you do not have continuity going across should end up being your problem. Your wires from the cord will attach on the motor were there are black dots next to the wire tabs. You could try touching the wires together that go to the switch and see if the motor runs if you do not have a meter and if it does then you do have a switch problem. If you can check those things let me know how it comes out and if that does not take care of it I will try to figure out what else might be the problem.
Mar 14, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Dark screen
While dismantling you have to be careful in handling the display chip. In all probability the supply wire to the display has cracked. There will be two supply wires to the display. Check its continuity. If there is no resistance or continuity, you will have to change the display
Oct 21, 2011 | Samsung SGH-a737 Cellular Phone
The Ungar we use at work was working just fine. Tried turning it on after only a short time of usage to shrink some shrink on a cable and she wouldn't fire up. Pulled her apart and can't see any really...
When testing a diode you need to lift one end of the component to prevent a second path of continuity. If you lift one end, and you have continuity in both directions when reversing the polarity, it would be shorted or defective. Does your Fluke have a Diode or Semiconductor setting? This will show you the voltage drop for the N/P junction which will be a better test than using the Ohm setting. If the diodes check good, test the motor windings, switch and heating element.
Mar 03, 2011 | Weller Ungar 1095 Dual Temperature Heat...
My toro model 51599 ultra with metal impeller began to overheat and shut it self off... is there a reset switch...this happened after moderate use tnx
If you take it apart there is a little spring on the bottom of the motor. When overheated it "trips" and looses contact with a wire. Need to reset the spring.
Feb 17, 2011 | Toro Blowers Rake and Vac - Electric...
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
222 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
