Problem. it might be stuck against the belt. I have seen the transfer blade flip before and ca
SOURCE: copiers
Not sure what you are looking for here. You are correct c010 is error code for main motor drive. You might check to make sure everything is able to move freely in the paper path. Check for paperclips, staples, crumpled paper anything that would hinder the movement of the components connected to the drive motor. If everything checks out and you can verify the motor is getting power then you are likely looking a replacing either the drive motor itself or the electronics that drives the motor. It may be prudent to have a qualified service person look at it before you spring for the board or motor though. Good luck have a fabulous day.
