Question about Roper RAS8445KQ Top Load Washer
Spin switch is broken - Roper RAS8445KQ Top Load Washer
I have a Roper Washer that the spin cycle quit working? Can hear motor & clicking sound, any idea?
Posted on Jun 27, 2009
  • 351 Answers
Go to whrilpoolpartssurplus.com and call mark i have the lid switch on sale and can ship cheap
Posted on Jun 24, 2009
Haier HLP20E washing machine won't spin & drain.
Haier HLP20E washing machine won spin drain Google Search
Cause 1Lid Switch Assembly The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Parts Cause 2Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Parts Cause 3Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Parts
Jan 13, 2018 | Haier Washing Machines
Dryer machine whirlpool does not spin
Be sure the child lock switch is working. If the door is not closed,it won't spin. If the switch is broken, it will not spin.
My door switch broke way back when.I bypassed it.Not a good Idea if you have children.
Feb 21, 2013 | Whirlpool Dryers
Washer not spinning at all. But all else works
the lid switch is most likely broken (washers will not spin out if the lid switch is broken
for safety reasons). Hope this helps.
Jun 08, 2011 | Kitchen Ranges
My front load washer won't spin
Hi There,
If your washer does not spin there might be two conditions:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. If the problem lies here Call a qualified appliance repair technician.
If none of these work then Do get back to us for any further assistance........
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine won't shift from rinse to spin cycle
Your lid switch is broken.
Unplug the machine and check with your hand for broken pieces under the lid switch hole.
Replacing this can be really easy.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
My Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Jan 15, 2010 | Washing Machines
Water enters and washes but no spin
check to see if lid switch is not activated or is broken, or more correctly open. You can test by inserting jumper in place of switch. If unit spins, switch is bad or missaligned. Most time I find the little plastic peice that in on the lid is broken off and there the switch is not pushed down when the lid is closed.
I idea behind the switch is to keep you from sticking your hands in a spinning washer.
Jul 21, 2009 | Washing Machines
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
96 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
