Question about Amana ABB2227DE Bottom Freezer Refrigerator
Refrigerator section does not get cold . the freezer seems to be alright. No airflow coming from the top center vent grill in refer. compt.
  • 351 Answers
Most likely a defrost problem that usually prevents air from going over there, or you fan is bad inside, i can give you free step by step directions on how to fix this whirlpoolpartssurplus.com mark
Posted on Jun 24, 2009
Why is my Freezer not cold?
If you block the vent that gives airflow form the freezer to the fridge it will prevent the airflow and so reduce the cooling in the freezer. Check that you don't have something against the vent that is located on the freezer side of the fridge in section.
Nov 30, 2014 | Samsung RSG257AARS (241 cu ft) Side by...
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
Freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FRT21H8 Top Freezer...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
What would cause my frigidaire refrigerator to not get cool p/n 240508000
Hello - If I may suggest, as it is a Top Mount; there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Nov 04, 2012 | Refrigerators
The freezer is cold but the lower section is warm.
If your freezer section has a knob that says "Colder" then set it to the left instead of
to "Colder"
Many people mistake this for a cold control but it only closes off airflow to
the lower compartment from the freezer section.
The freezer supplies cold air to the lower compartment. You may also want to see if the vent to the lower compartment is
blocked with ice. (The vent duct is the plastic duct in the freezer compartment).
hope this helps.
Jul 31, 2011 | Refrigerators
Freezer and Ice maker are working refrigerator is not what can be done to the vent thing at the top (center)? I have removed the cover. I have had this happen three times while under extended warranty...
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 100% reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
One is the temperature thermostat, it actually controls the compresssor motors cycling,
thus the desired ice box temperature as well, it often says 1-10 and off as well, the reamaining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the reefers box!This is where the problems occur, when one notices the reefers box is warm, they max both settings,which seems logical , and is for the thermostat dials setting.Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!not Colder Reefer! so you MAX or RAISE the thermostat, thats ok to do.But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm in another day or so. But if the freezers making ice for days and never getting wet theres an airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it iced up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons of water.
Dec 20, 2010 | Maytag MFD2560HES Bottom Freezer French...
Kenmore coldspot(side-by-side) Model:106.56612500,Type2555A;MFG date:Aug.2006. Freezer and Refrigerator Control both at factory preset position(center). Problem:Left frozen section seems colder than usual...
The defrost system is not working. Ours had a sensor go bad that clips on the coils inside the freezer and can tell when their is front. When it is not working the frost just keeps building up because it down not call for the defrost heating wire to ever come on. It could also be that the wire is bad or that the control panel is not responding the the sensor. It sounds liek the issue is no defrost cycle though.
Oct 06, 2010 | Kenmore Refrigerators
Amana ABB2227DE Bottom Freezer Refrigerator Logo
457 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
