Question about Homelite Mighty Lite Lawn Trimmer
TRIMMER WILL NOT FEED LINE - Homelite Mighty Lite Lawn Trimmer
  • 1,041 Answers
Have you tried bumping it on the ground as you give it throttle? If so, then the line itself may be too large for your trimmer.
I really need more information to answer the question accurately though.
Jim
Posted on Jun 25, 2009
  • Jim Parker
    Jim Parker Jun 28, 2009
    Did this solution solve the problem?
    Jim
How do you pull out more line on toro 910 home trimmer
The feed bump located on the bottom of the unit is the portion of the head that you tap on the ground to feed more trimmer line as you are trimming!
Mar 18, 2017 | Toro Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Cut line the proper lengh feed thru until both sides are equal start trimming and the line will not feed
You are describing a problem that could be related to the line being too big for your trimmer. It should say what size trimmer line to use in your manual. It may even say on the piece that the line winds around; but you have to look very close
If your line is .080 it may be too big. You should probably use .065
Jim
Aug 06, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Trimmer line on spool of Challenge 250 Watt Grass Trimmer.will not automatically feed as it is supposed to do when tapped on firm surface - can you let me see by diagram how the line is feed onto spool and...
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
Oct 12, 2009 | Garden
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
Automatic line feed melts together -will not feed- second trimmer to do this
The talcum powder fix that I gave for line feed problems works for this problem too. The powder lubricates the line, eliminating the friction that melts the line. They are essentially just two parts of the same problem.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Homelite Mighty Lite Lawn Trimmer  Logo
285 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
