Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Frost is building up on the top and back of my Kenmore freezer refrigerator, model 6825480. It is only 6 months old. I'm wondering if it could just be the temperature control is too high (cold).
  • 351 Answers
No sounds like a defrost problem.... still under warranty isnt it?
Posted on Jun 24, 2009
Frost buildup in freezer
this unit is under warranty if it is 3 months old you may have a defective defrost timer staying too long call for warranty.
Dec 11, 2013 | Kenmore Refrigerators
I had water in bottom of kenmore fridge. This is now fixed but soon after I had frost building up on back wall of freezer.
you now have a defrost issue,remove rear panel inside freezer if the evaporator is covered with a heavy ice and frost build-up then either the defrost heater under the evaporator coil is open or the defrost thermostat on top of the coil is bad you need to check both for continuity or the defrost timer if equipped or the A.D.C. adaptive defrost control is bad and not supplying power to the defrost circuit
May 02, 2012 | Kenmore Top Freezer Refrigerator
The freezer section of my Kenmore refrigerator isn't freezing
Defrost cycle is not working correctly. Bad defrost timer, heater or limit thermostat.
Sep 11, 2009 | Kenmore Refrigerators
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
I have a Kenmore refrigerator (model 253.63732300) with freezer on top. The freezer section is cold but the lower section or the refrigerator section is not cold. It is warm. Any suggestion on why this is...
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Jun 14, 2009 | Kenmore 61042 Top Freezer Refrigerator
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
May 28, 2008 | Kenmore 60721 Refrigerator
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
